Question about Sewing Machines
WHAT SIZE IS THE BOBBIN? I NEEDTO BUY SOME .I IS NOT IN THE INSTRUCTION MANUAL
  • Sewing Machines Master
  • 1,133 Answers
Bobbins are different between machine manufacturers so you will need to establish what make and model you have first.
The manual should show the bobbin style, ie plastic, metal, holes on top only, holes top and bottom, tapered top or flat.
It is essential that you use the correct bobbin for your machine so check what is in it now and take one with you when you shop for more to ensure correct match.
Posted on Mar 29, 2011
Need manual instructions for Riccar 2910 need help with bobbin, threding machined and tension setting and bobbin holder.
You may be better off going to google and search "riccar 2910 manual" That way you can follow their detail dorections rather then someone elses and it confuse you. Usually the PDF versions have pictures with it :-)
Apr 07, 2016 | Riccar Sewing Machines
"bobbin size
Consult your owner's manual to find out what bobbin to use in your machine. There are many bobbins available, some will actually fit in your machine, but they may be a slight bit different size that will negatively affect your machine's operation. If you don't know which bobbin to buy, take the machine's manufacturer name and model to a sewing shop and ask if they can sell you the bobbin for your machine. Better yet, find a local dealer who supports your particular machine's manufacturer. You may even find the appropriate bobbin online by searching:
Manufacturer + Model + the word "bobbin"
Dec 30, 2015 | Sewing Machines
What bobbins fit the singer featherweight 117
The Featherweight II 117 uses the Class 15 bobbin. A 4-pack of the Dritz equivalent of the bobbin is available from Amazon here: http://www.amazon.com/Dritz-Plastic-Class-15-Bobbins/dp/B000Y3D1NG . Singer has a 10-pack of the bobbins here: http://www.singerco.com/accessories/detail/2075/class-15-bobbins-10-pack . You can buy a manual from Singer, as well. (See their Instruction Manual page from the Customer Support Link then enter 117 in the Search box.)
I hope this helps.
Sep 07, 2011 | Singer Featherweight II 117
Thread is balling up and not allowing the fabric to move it isn't stitching right
This can be caused by several different things. Check the threading. Un-thread the machine and follow the guidance on the manual and re-thread the machine. The bobbin, if the bobbin thread that coming out of the bobbin case in a wrong direction, could cause this. Re-set the direction. When you pull thread from the bobbin case, bobbin should roll counter clockwise. The needle, if it is not the right size needle for the fabric or the needle is slightly bent, maybe replace the needle and try with different size of needle. Once its balling up, sometimes it's left some thread in the machine under the needle plate around the feed dog, clean them up. Thread tension, different fabric may need to be adjust the thread tension, try to check this one under the manuals/instruction. When ready, check and use a scrap of fabric/remnants!
Aug 02, 2010 | Riccar Sewing Machines
Bobbin size
This machine uses a class 15 bobbin.
Nov 01, 2008 | Simplicity Fashion Pro SW2145 Mechanical...
White W100 Mighty Mender Sewing Machine Instructions
I have the "mighty mender" instruction book you are looking for everyone !! Happy to help all you sewers out there!
http://www.hammerwall.com/Download_Manual/70097/
Apr 10, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
