Question about Dryers
It is a Maytag PYG2300AWW (gas). It starts up and works fine for a while then the heat cuts out and the burner doesn't relight until you shut it off and let it sit for a while then does the same thing. I had it apart and did a thorough cleaning but that didn't help. Any suggestions what to check? Thanks, Eldon
    Sergeant:
    Champion:
  • 202 Answers
You have bad gas coils if the heat cuts out and then won't relight
Posted on Mar 23, 2011
My heater works fine until the burner shuts down at which time the pilot also goes off and naturally it can't relight.
Check pilot is not blocked .Short pilot going off when burner does .check flame sensor and thermocouple
Dec 10, 2017 | Heating & Cooling
The oven comes on an heats up to temperature , after a short while the oven no longer continues to heat. The contol panel shows on in bake mode , but the oven continues to cool.
Hello Brian;
You did not provide any information on the unit that you have. After you open the oven door there is a metal label on the face of the oven. Send that to me so I can see what you have.
1.) Some ovens have a single or dual broiler thermocouple.
2.) Some ovens have a separate control board for the oven.
3.) Some ovens have a Infinite switch.
Mar 21, 2015 | Kitchen Ranges
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
My Maytag pyg2300aww will not shut off when I open the door,I just replaced the high limit and thermal fuse..Everything else is working fine..Thankx
I would take a look at the door switch, its a push button on the top of the door opening. The spring might have went, causing the switch to stay closed, hence it staying running
Aug 04, 2010 | Maytag PYG2300A Gas Dryer
My gas dryer starts normal but then the flame stops and it cycles trying to relight it
Replace the 2 coils on the burner . After warming up , 1 will " short " internally , opening the circuit . After the dryer cools down , completely , it will work again , until the coil warms up . Only 2 screws hold the bracket holding the coils on , Gas does not have to be turned off to replace these coils . Easily replaceable .
Apr 18, 2010 | Maytag Dryers
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
Maytag gas dryer would run half cycle until it would shut down. now it struggles to start and then stops. pyg2300aww model.
Good day,
Every indication the motor is failing. Not uncommon.
Could be a bearing dragging badly, or idler assembly bearings, doing the same thing, but
A complete tear down of the dryer would need to be done to verify the problem.
Once again,figure the motor as the problem.
Thank you for using FixYa
Dec 25, 2009 | Maytag Dryers
My Maytag PYG2300AWW is not heating. I have gas flow and the ignitor lights. But I noticed that when the temperature start to increase the flame goes out, and as soon as the temperature goes down, the...
It will shut down the heat if the vent or lint screen are plugged , are they free ? Also try washing off the lint screen with hot water, somtimes wax builds up on them from the sotener and wont allow air flow, you wont see it on the screen it is clear, but water will bead right up on it. easy checks before replacing a thermostat
Oct 29, 2009 | Maytag Dryers
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
3 yr old amana gas dryer not working
i would replace the coils mounted ontop of the burner valve. they're overheaating nad not opening the valve after heated.
279834 twenty bucks. comes as a set replace both coils!!
Mar 10, 2008 | Dryers
Dryers Logo
96 people viewed this question
Top Dryers Experts
