Question about Airlink Computers & Internet
Wireless connection problem
My wireless connection cant detect the router...its saying there is no wireless connection found in range...
  • 35 Answers
Hello There, are there any wireless computers that detects your router? If there is, most of the laptop computers has a built-in on/off (toggle) switch on the side to enable or disable the wireless card on your computer. Make sure it is "ON" then check if it will detect the wireless connection.
If it is a desktop, try to reboot the computer then check again. If none of the computers can detect your router, make sure that the wireless light on the router is lit up. You may also try changing the channel on the router.
Posted on Aug 03, 2008
Cant connect to my wifi saying scanning or it diconnect
hi, click open the wi-fi icon bottom right of your screen . you should have a list of connections in range. check your router to find out which one is yours. click on that and enter the code found under your router ( these are usualy all in caps ) if it cant find your router then the problem is with your router ( unplug it and leave it off for a few moments ) or your wireless is not turned on,on your laptop. if it dose find it but wont connect,your problem is with the wrong code entered..hope this helps
Apr 22, 2015 | Nordic Track NordicTrack X 9I INCLINE...
Tip
I get "no Wireless networks were found in range" when the laptop is sitting...
Configure Wireless Zero Configuration to connect to wireless network on your wireless XP computer.
Below mentioned steps will help enable Wireless Zero Configuration on your XP computer and achieve wireless connectivity. These steps applies to your XP wireless computer (Desktops and laptops) with external or built in wireless cards.
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight the SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button. You should have successfully established a wireless network connection.
The above steps will help you in the configuration of wireless connectivity if you are not aware about the settings of wireless connection utility installed on the computer.
on May 31, 2010 | Computers & Internet
Network adapter hp6505f
If your computer has a wireless network adapter, Windows will automatically detect wireless networks in range of your computer. You can see a list of wireless networks that Windows has detected in Connect to a Network.
  • Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
If Windows doesn't detect a network that you think is in range of your computer, it could be because of one of the following reasons:
  • The wireless switch on your computer is turned off.
    Many laptops have a wireless switch on the front or side of the computer. If your computer has a switch, make sure it's turned on. Some computers also use a function key combination to turn the switch on or off. Check the information that came with your computer for details on locating the wireless switch.
  • Your computer is too far from the wireless router or access point.
    Move your computer closer to the router or access point. If the computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer.
    If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than a built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna.
  • The wireless router or access point is turned off or isn't working properly.
    There are two things to try:
    • Make sure the router or access point is turned on and that the wireless signal light is illuminated.
    • Reset the router or access point by unplugging it, waiting at least 10 seconds, and then plugging it back in.
Sep 10, 2012 | NEC Computers & Internet
I have an old wannadoo live box on orange worked fine until I moved home. Orange have confirmed that internet has now been set up at my new address and I kept my old phone number. The LAN into my...
i assume you have DSL connection through phone line . double check the cables see if they are connected properly betwee the modem and router etc ..if its all connected then reset your router by pressing littile tiny button at the back of Router and apply new WPA2 password and try connect .
May 12, 2011 | Computers & Internet
I have belkin connect n150 and i have two laptops my one laptop is connect to wireless but the one laptop cant access to wireless it says no wireless network were found in range..
If your message is like this " no wireless network found in range make sure wireless on the computer is On". All you need to do is look for the wireless switch usually located on the side or the back of your laptop. Sometimes its near the F keys or start button. You may check your laptop manual to see where to locate the wireless switch , or you can check the laptop manufacturers website usually they gave information on where to locate or enable the wireless feature of laptop.
KA
Mar 30, 2011 | Belkin Basic Wireless Router
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    I have a wireless router but cant seem to take my laptop in to another room for use. screen comes up that says no connection,should'nt i be able to use it wireless within the 100 feet range?
    In my experience being within 50 ft of various routers I have had seems to be the best singal strength. Any further then that I start having connection issues. So based on my experiences I would say the answer is No to your question. That is based on 'G' system routers. I have heard the 'N' routers have greater range and speed.
    Nov 10, 2010 | 2wire (1000-400108-001) Router
    D-link dir-625 still cant acces wirelessly
    If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
    Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
    D-Link DI-524 4 Port connection Problem.
    Perhaps the router is not broadcasting its SSID, therefore is invisible to would be tappers. Type 192.168.0.1 into a browser on a computer directly wired to the router, leave the username blank, if you havent changed it, the password is admin by default. Once logged in check that wireless is enabled and that you are broadcasting the ssid, you may want to setup/change security settings for the wireless connection at this time also.
    Feb 11, 2008 | D-Link DI-524 4 Port Wireless-G Router -...
    Dlink dkt-110 wireless router
    All right, according to your question, i'll asssume your pc running with win xp..first connect the wireless card to the computer and restart it, the card should be detected, you should get a found new hardware screen then insert the cd and continue installation..if you do not get the screen check in a diff pc if you stillk do not get the message.. the problem is with the pc card or else with the pc where you are trying to install the card/..
    Dec 04, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
    Computers & Internet Logo
    178 people viewed this question
    Top Airlink Computers & Internet Experts
    Prashant M
    Prashant M
    Mike
    Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
