Question about Whirlpool Refrigerators
I cannot understand my settings on my whirlpool arc 8140/1/1x . the fridge will not go cold could you help me?
2 Suggested Answers
  • 2006 Answers
SOURCE: My whirlpool fridge is not
Your cooling comes from the freezer side through cooling tubes to the refrigerator side.
The first thing is to make sure that the evaporator fan is working, because that will blow the cold air into the refrigerator side. If it is working then you probably have an ice build up around the evaporator. You will need to remove the inner rear panel of the freezer to check it.
If there is a lot of ice on the evaporator fins then your defrost circuit is not working. But if you manually defrost the freezer (a hair dryer will speed it up) and make sure the cooling tubes are clean of ice (can feel the air from the hair dryer on refrigerator side) then you will have anywhere from a few days to a few weeks before the ice build up returns.
So you should troubleshoot your defrost circuit and get the parts on order to be ready for the next time.
Posted on Jul 15, 2011
Calibration screw fridge
Try the thermostat on it's lowest setting first. If it doesn't switch off soon enough and gets too cold, you can get different thermostats from your supplier. A bottle fridge thermostat would suit.
Apr 21, 2012 | Whirlpool Refrigerators
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
The reezer works fine it is the botoom fridge that frezzes up and stops air flow to keep cold thanks bellystar
I will try to help you but you need to look around the door and near floor and behind the fresh food section door. I need the model of the Whirlpool refrigerator. Sounds like the thermostat is stuck or broken on as cold as it gets. There are just too many models to guess. This still may take a little work so let me know when you are ready, Thanks for understanding, Sea Breeze
Oct 20, 2009 | Whirlpool Refrigerators
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Whirlpool intgrated fridge/freezer is not keeping
7 is coldest. but how cold is the freezer? all cold is made in freezer. ma be developing a frose problem
Jul 06, 2009 | Whirlpool ED2GHEXN Side by Side...
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge side by side and freezer not cooling
The fridge is working again and I don't understand why. Thanks anyway all is good.
Jul 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
90 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
