Question about Amazon Stores
There is a permanent gray line at the top of my kindle 3. I have tried resetting it, and it wont go away.
  • 158 Answers
It may be a hardware defect already since you already tried resetting it. if its still on warranty try to have them replace the unit. most likely you will need the help of a service technician to replace the lcd.
Posted on Mar 23, 2011
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
I thought I deregistered it and gave it to my daughter but my name keeps showing up and it wont let her register under another name.
How to reset / restart your Kindle - YouTube
? 1:42
www.youtube.com/watch?v=XXj8PuYYY4Y
Feb 4, 2013 - Uploaded by Pieter De Waal How to reset / restart your Kindle. ... It won't reset or anything. .... Amazon Kindle 3 3G/GSM/WiFi 6" TEARDOWN - EEVblog #109 - Duration: ...
Oct 03, 2015 | Amazon Kindle 3G
I charged my kindle, but can't get it to turn on
According to Love My Kindle Fire, nearly every Kindle owner will, at some point, need to learn how to "reset" their machine.
"When I hear (or read) these words from those who are experiencing a problem with their Kindle Fire it usually ends with something like, "turn on", "charge", or "work".
If suddenly your Kindle Fire won't work, then its most likely locked up. However, sometimes when it locks up, you can't tell because the screen goes dark (either gray or black). It just looks like it's off when in fact it is already one. cause the screen goes dark, either gray or black. It just looks like it's off when in fact your Kindle Fire is on but is stuck. When an electronic device locks up or freezes usually resetting it fixes the problem. Resetting your Kindle Fire is actually really easy, just hold down the power button for at least 20 seconds. .If your Kindle Fire won't turn on it's possible the battery went dead (if it was left "on" too long).
Plug in the power charger and wait about 15 minutes to make sure it gets enough charge, and then try turning it on again.
If it still won't turn on, try to reset the Kindle Fire again to be sure it's powered off.
If it still won't work, try someone else's charger, in case yours died.
Mar 03, 2015 | Amazon Kindle Touch 4gb, Wi-fi, 6in -...
How do I get my kindle to switch off
if it's left turned on, it will turn off when the battery runs out.
Jan 29, 2015 | Amazon Kindle - 6 Inch E Ink Display...
How do I get the voice activation to go away? it only wants to tell me what button I am pushing and wont go where I want. please help me make the voice be quiet before I lose my mind!
Go to your accessibility settings menu on your kindle..
1) Tap and hold the top bar on the screen and then pull the bar downward to view the settings menu.
2) Tap more , to view additional settings.
3) Tap the accessibility option to open the access menu.
4) Slide the text to speech to off.
5) Slide the voice control to off.
6) Tap the back arrow to save your settings and to close nenu.
Ellen
Dec 19, 2014 | Amazon Kindle Fire HD
Forgot password to my kindle fire. How do I reset
1 Connect the Kindle Fire to your computer using a USB cable.
2 Wait for your computer to recognize the Kindle Fire device, and select the option that allows you to view the contents and data stored on the Kindle Fire.
3 Copy or move the Kindle Fire files you want backed up over to your computer's desktop or other location.
4 Right-click on the icon for your Kindle Fire located on your computer's desktop, and select "Remove" or "Eject."
5 Remove the micro-USB cable from your Kindle Fire. After you reset your Kindle Fire, you can follow these same steps to move your saved files back to the Kindle Fire from your computer.
Part 2 Reset the Kindle Fire
1 Tap on the "Quick Settings" icon on your Kindle Fire. The icon is shaped like a wheel, and is located in the status bar at the top of your Kindle Fire.
2 Tap on "More."
3 Tap on "Device."
4 Tap on "Reset to Factory Defaults."
5 Tap on "Erase Everything." Your Kindle Fire will reboot, and display a message that confirms the reset process.
When the Kindle Fire has finished resetting, it will reboot once again, and display the initial start-up screen.
Oct 02, 2014 | Tablets & eReaders
Top portion of screen has black and horizontal/vertical white lines. When I turn it on screen is dark gray and unreadable. When pushed to turn pages, lights up briefly, then goes dark gray again. Worked...
Try to hold the slide key for 15 sec. It will reboot your kindle. If black patch is not gone even after that, It's a hw issue. Screen might require to be changed. If it's in warranty Amazon will do it free. That's what i have heard.
Mar 01, 2011 | Amazon Kindle Wireless Reading Device
Display has permanent dark bar in upper corner whether the kindle is off or on. Reset does not fix the problem.
You screen is broken. Try Amazon, they should give you a replacement. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Jan 28, 2010 | Amazon Kindle 1
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Amazon Stores Logo
93 people viewed this question
Top Amazon Computers & Internet Experts
Craig Butler
Craig Butler
Raghavendra Nagaraj
Raghavendra Nagaraj
Tom Chichester
Are you an Amazon Computer and Internet Expert? Answer questions, earn points and help others
