Question about Compaq tc4200 Tablet PC
HP Tablet TC 4200 without pen.Can I use the touch screen and operate by the fingers, or it is needed pen digitizer?
  • 56 Answers
It will need the pen to work.
Posted on Mar 23, 2011
Ello My problem is when i boot after a factory reset i have touchscreen to calibrate and when i do it it gives me try once again it's stuck there
I am not sure you are talking about a tablet PC or the new craze of tablets.
For the tablet PC you should have a screen calibration utility. You can calibrate the display for the Wacom (or other) pen, or for the touch input.
When you calibrate the pen, any touching of the screen with anything other that the Wacom pen will be ignored.
Similarly, when you calibrate the touch, any input with the Wacom pen will be ignored and you will be asked to use the proper instrument.
To get back to your case , it is possible that you are not putting the finger at the right place or not pressing hard enough. That is just a guess and I may be off the mark for the new tablets, but not for the Tablets PC:
Apr 07, 2012 | Tablets & eReaders
I have a Toshiba R15 S822, my problem is that my touch screen is not working, I would like to know how do I reset my computer to factory setting?
I might not be necessary to reset to factory settings. Just go to the Toshiba.us support site and download the drivers for the Tablet PC (that includes the WAcom driver, all the tablet PC extensions).
If you have the Recovery CD, you can run it from inside Windows XP and reinstall selectively all you need.
Just to set things straight, the screen of the R15 reacts to the Wacom pen only, not to your finger or some other plastic tipped pen.
Aug 14, 2011 | Toshiba Satellite R15-S822 Tablet PC
Pen and touch screen
Please repost this with more information on what your problem is. At this point, we have no idea what your problem is, it just says "Pen and touch screen".
Hope this helps, Nathan Taylor
Jul 23, 2011 | Compaq tc4200 Tablet PC
I have a Toshiba tablet M780-s7230 and i tried reinstalling the touch screen driver and my tablet pen and touch screen still don't work what else could i do?
Have you turned on the Touch feature on Windows 7 yet? That could be the reason why your touch screen feature is not working.
To turn it on please follow this:
1. Open your Start menu and type "Touch" into the search bar. This will show a variety of options, including the "Pen and Touch" options. Double-click it to open the "Pen and Touch" window.
2. Check the boxes next to the "Use your finger as an input device" and, if preferred, check the "Enable multi-touch gestures and inking" box as well.
3. Click "Apply" to set the options and click "OK" to exit the window.
Hope this helps!
Apr 10, 2011 | Toshiba Portege M780-S7230 Tablet PC
Touch screen and digital finger scan's not working
there is one option that you have tak back-up your data then run recovery disk that is only solution becoz touch screen and finger print software is realy delicate things dont try to paly with if don't have to downlod drivers from the HP site
May 14, 2010 | HP Pavilion tx2500z Tablet PC
My HP Compaq tc 4400 tablet screen keeps on flipping with out doing anything
The tablet buttons can be disabled to stop your screen from rotating. Go to Control Panel > Tablet and Pen Settings > Tablet Buttons > select the rotate button and click change > select "None" on the drop down menu.
Feb 22, 2010 | Compaq tc4400 Tablet PC
My slate vision tablet pc is having some problems. The screen is not reacting when the pen touches the screen. I went into the control panel seems that everything set up correctly. Could it be the pen that...
Your tablet pc uses the Wacom Digitizer so the pen does not use a battery. It is possible that it could be the pen or the screen. It works with electromagnetic resonance technology and the screen produces this signal that the pen grabs, converts, and returns to the screen without batteries. The pen does contain compenents that can fail but so does the screen. You could try buying a replacement pen for around $20 dollars and see if that works. Worst case you would be out $20. If you had another tablet PC that uses a Wacom screen you could try the pen with that one or test the other pen with yours.
Sep 28, 2009 | FIC SlateVision Tablet PC
Pen pointer problem
you can try calibrating the pen that would probably help
Jun 02, 2009 | Compaq tc1100 Tablet PC
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Aug 21, 2008 | Itronix Duo-Touch Tablet PC
The Pen
I'm not familiar with your laptop but judging from all the pdas I've had with touch screens the pen itself is only a pen, you could basicly use a wooden stick to poke at the screen and it shouldn't make a difference to the computer.
this laptop has a touchscreen If I'm not mistaken and you should be able to use it even with your fingers.
You might have a faulty touchscreen or then you need to install a driver for the screen?
Jul 04, 2008 | Averatec 3500T60 Tablet PC
Compaq tc4200 Tablet PC Logo
680 people viewed this question
Top Compaq Tablets & eReaders Experts
Vernon Taylor
tosin_christ
alibaba69
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
