Question about HP vs17
I have a HP vs17 LCD monitor 17" I relaced the screen and don't remember how the wires go to the back lights. They are the pink and blue wires on the side of the power board. Can you help?
  • 11,361 Answers
Pink and Blue wires should be for the lamp assemblies, you should have four connectors for the lamps, each pair will be plug into the socket top set and bottom set.
See example here:
http://s807.photobucket.com/albums/yy352/budm/HP%20L1740/?action=view&current=DSCF1597.jpg
Post pictures if you are not sure.
Posted on Mar 24, 2011
Hp 17d monitor black screen
More info? Does monitor turn on any? Have you eliminated backlight from problem? Any LED lights on, if so what color?
Jan 12, 2013 | HP Vs17 17" LCD Flat Panel Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
Monitor hpvs17e stays on for second and goes blank
gldngrlz411, most likely problem with internal "switch-mode-power-supply" / CCFL inverter supply that provides 600 to 1000 volts ac to light the CCFL tubes that provide "white light" so you can see what is on the glass LCD panel!! Explore here first: http://www/lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ If vs17e does same when connected to a different "known good" pc, then you will need to make big decision!!! FIX or Trade in for new wide screen unit. 12fixlouie
Oct 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hi, my screen just randomly turned pink im wonderi...
Check all the pins on the VGA cable, also try it on another PC to make sure it is not the PC that is causing the problem. Hopefully it will not be bad lamps.
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
May 20, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Power light on flashing but no screen
Hello.
There is either a problem with your monitor, VGA cable or PC's video connector. Try another PC or another monitor to narrow down your problem.
If another monitor works, swap the VGA cable on your old monitor.
If another monitor doesn't work, your video connector is faulty.
Hope this helps.
May 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Hpvs17e white backround is pink
hucknannie, Power down the pc and monitor. Then disconnect and reconnect the VGA cable a few times to the rear of the pc. then turn system back on and re-boot. If your "PINK" screen still there, then you may need to have unit refurbished with new "cold-cathode-fluorescent-lamps" or have the internal "switch- mode-power supply/ccfl-inverter-supply" inspected and repaired. Yes, before you do anything, visit this web blog about HP monitors!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Read and make note that people are still visiting the blog even after 4 years!! Hope this response helps. Feel free to leave a comment and also rate this response on fixya. 12fixlouie
May 03, 2010 | HP Vs17 17" LCD Flat Panel Monitor
I came back to the computer and the screen was blue with nothing on it. I finally turned the monitor off and then back on. A quick box appeaers saying imput:analog, disappears, and then the monitor remains...
OS system corrupted & display driver lost. 1st try to install display driver hope you see the good result. if not then you need to format the OS and installed it again.
Jan 30, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor flashes blue light and takes a long time to come on
Disconnect monitor cable from back of the computer and see if u have a error msg on the screen > if u find a error msg like " NO VIDEO SIGNAL"> then ur monitor is fine or else ur monitor is BAD
Oct 20, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Black screen, flashing blue power light
Chek the RAM of your system. Clean the slot and re-fix the ram. If the problem not solved replace the Ram
Jun 17, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17 Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
