Question about RCA L40FHD41 40. in HDTV
When i try to connect my laptop to my rca l40fhd41, it will show for a few seconds then a message comes up on the tv "unsupported" and it wont work as a monitor.
    Guru:
  • 276 Answers
You need to reset the laptop video screen output resolution and refresh rate to something compatible with the HDTVs acceptable parameters. Consult the TVs owner's manual for a chart showing the acceptable screen resolutions and refresh rates. You are looking for numbers like 1024 X 768 or 600 X 800 for screen resolution. Your laptop will allow you to setup different screen resolutions for output. You just have to find one the TV likes.
Posted on Mar 23, 2011
Precision tv
If the TV accepts a USB connection try that format. If you have a HDMI port of the laptop, tether the two with an HDMI cable.
Other than that, unless you have WiFi capability between the laptop and TV receiver....nothing else works.
Dec 15, 2013 | Televison & Video
Problem with VGA signal
Try using a HDMI cable instead
Please help. Hooked up Toshiba Satellite to l40fhd41 RCA using VGA cord and video shows up on PC channel of TV. My problem is the sound. Trying to get sound to TV using earphone port on Laptop with...
If you look real close at the VGA port on the TV, you will see a small mini phone jack 'AUDIO' that is for attaching the audio cable with mini stereo phone plug at both ends, one end is to the TV PC audio input jack, another end goes to the PC AUDIO line out or headphone out.
Dec 31, 2010 | RCA L40FHD41 40. in HDTV
I want to use Trutech 19" tv as computer monitor. Scrreen starts to set up and then get error message "Unsupported Mode." Is their a simple fix for this?
Hello Fayeburns,
Yes, there is a simple fix for it.
The reason why your TV is showing Unsupported Mode is because of the display resolution of your
graphics card, which is higher than what the TV can handle.
What you can try is, when your system is powered up, just go to your display settings, then
reduce the systems display resolution to--preferably 800x600 or 1024x768, then go to where you
normally select the output, and select 'Output to external monitor"...this should send the signal
input to the monitor.
In case it still doesn't work, just try and update your graphics card driver to the latest one and try
the same process again.
Most Laptop graphics display resolution are generally very powerful as compared to what the TVs
can handle.
Try this out and let me know how it goes.
Hope this helps.
Goodluck and thank you for using Fixya!
Dec 26, 2010 | Computers & Internet
I hooked up my tv,a sony bravia bx3 to my laptop using an hdmi cable which i disconnected from myps3 while it was still on,it worked perfect.suddenly the ps3 switched off.I re-connected my ps3 to the tv...
ok you have to reset the ps3 by turning of backswitch wait 10 seconds turn on the backswitch then press and hold down the front power button for 10 seconds you should hear 2-3 beeps that does it just wait and the video settings have automatically detected your tv settings and are going to ask you to save hit x to save display settings on ps3 remote problem solved. If you still get problem message me cause its technically bad.
Dec 15, 2010 | Video Game Consoles & Games
Message of Unsupported video signal after attaching laptop to TV.
it sounds like the resolution the laptop is trying to send is not one of the resolutions that the television can display. TVs can display a range of resolutions, so try changing the laptop resolution, either increasing it (make the pixels smaller) or lower the resolution, try a variety of resolutions, one should work.
Jul 11, 2010 | Dell Latitude D420 Notebook
Where can I get a power cord to fit the RCA L40FHD41 40 in HDTV TV?
It uses the same power cord as used for PC, try your local PD repair shop, It is NEMA5-15P to IEC C13 POWER CORD.
Jun 13, 2010 | RCA L40FHD41 40. in HDTV
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Jan 05, 2010 | RCA RT2380 Home Theatre System System
RCA universal nor cable remote will program RCA L40FHD41 TV
might be able to use the cable co remote and autosearch thru the codes, but its too hard to explain, the cable tech should have ran that procedure. unfortunately, rca has 50 million models. it is common to have a tv and yes rca for sure, to not take the codes. sometimes the tv is too new for the cable company remotes to work. i am leaning toward the tv too new theory. give it six months and i bet there will be a new remote version.
Dec 08, 2009 | RCA L40HD36 40 in. LCD HDTV
RCA L40FHD41 40. in HDTV Logo
159 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
