Question about Sony MHC-ZX70DVD System
Hello There I have Sony HCD-ZX70DVD with optical laser lens KHM-220AAA. Recenlty i changed my optical laser lens to new optical laser lens and i m facing a reading disc error like it says no disc but some times it reads but some times not reads and about DVD not even single one read it , i desolder the optical pickup for short before installing them into the mechanism. Now anyone there to help me out from this situation what's the problem to not reading disc's proper with new laser lens and any upgrade for laser lens to make them region free.... Thanks
SOURCE: player reads no disc
make sure you are putting them in correctly
Posted on Jan 27, 2008
SOURCE: Cant Read Disc
Unsolder transit solder pad near ribbon connectors
Posted on Feb 13, 2008
  • 4 Answers
SOURCE: "Disc Error" reads on Sony Handycam DVR-R
I bought a program called "inDisc Recovery" that locates lost files and then saves them to your computer.
Posted on May 20, 2008
tech48
  • 624 Answers
SOURCE: HCD-X1
There is only one thing that you can do as the end-user to try and fix this. Try cleaning the lens on the laser pick-up. Most retail outlets that sell CD or DVD players sell a cleaning disc for about $10 to $15. You put it in the machine and let it run for about 20 to 30 seconds. If the reason your DVD player won't play is because the lens is in need of a cleaning, this will fix it. If the reason is anything else it will not help at all. The most common reason for this failure is a faulty laser pick-up that need to be replaced. This is the most common and usually the most expensive repair because of the cost of the pick-up. It can cost anywhere from $130 all the way up to $200 depending on the labor rates of the shop and how much they mark-up the cost of the pick-up. All shops mark-up the cost of the parts. It is not advisable to do this yourself unless you have some experience with electronics and can do some troubleshooting to verify that the pick-up is indeed bad. It is easy to cause more problems than you started with if not done properly. As I stated above, it is the most common, but it is not the only reason. Other causes of this failure can be as simple as a bad voltage regulator or as difficult as replacing a servo IC. It can also be a memory IC (if it plays CD's but not DVD's), a spindle motor, a bad gear or switch, or one of many other causes. That is why it requires some experience troubleshooting them to nail down the exact cause.
I hope that this information was helpful for you to make a desicion on what to do with it, and if so, a rating of "FixYa!" would be appropriate and very much appreciated. After all, it is the only reward we get for offering people like yourself this free help and information.
Let me know if you have any more questions, I will be happy to offer you whatever help I can. I have over 18 years experience repairing these type of products. I have been repairing DVD players since they came out on the market for sale.
Dave
Posted on Sep 16, 2008
nuwan chinth
  • 111 Answers
SOURCE: Won't read dvd's or anything, just says mechanics error
no try to open the cover and inspect anything stuck in loading mechanisum.check the all reed swiches and clean all if they are dusty.
shall we try to repair it.
nuwan..
Posted on Jan 12, 2009
I have a Sony CD/tape player model # HCD-NE3. When trying to read a CD - it says NO DISC. What should I do?
Typically a no disc display indicated dust on the optical unit ( lens ) or failure due to low laser beam emission. For the first case you have to remove the top cover and clean the lens very gently with a ear bud. The the cleaning does not solve your problem you have to replace the optical unit itself. Unless you have experience doing the above i won't recommend it. Replacement will cost you about 15$ plus labor.
Aug 11, 2011 | Sony Audio Players & Recorders
When playing CD's it skipps.
hello johschmo,
propably the optical pick-up unit (also called laser-unit or lens) is worn out - replacing it with a new one will help to solve this problem. feel free to contact me for further assistance if needed. ****!
kind regards
Feb 13, 2011 | Sony CDP-CX335 300-Disc CD Changer
Sony HCD-GNZ77D dvd deck receiver DEST ERROR
if your sound system gives you Desk Error or Desk Read Error, try cleaning it with a lens cleaner, they can be found in many forms in the market. If the problem still insists then your system's lens ( the part which read the optical discs like DVD's CDs etc.) need to be checked by a professional technician, probably would install a new lens on your system. You can comment if you need more clarifications. Best of luck
Feb 13, 2010 | Sony Audio Players & Recorders
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
GETTING MESSAGE NO DISC WHEN THERE ARE 3 DISCS
Plain and simple. The device is broken. I can only say the laser might be dirty.  Perhaps get a laser lens disc cleaner. and check to see if that works. If not you should send it off to an authorized specialist. Or if you are feeling brave take it apart yourself.
Sep 02, 2009 | Sony MHC-GX450 CD Shelf System
Do you know where the solder point on a new laser lens is located that has to be removed?
It's opposite the ridge where the type of lens is scribed (PVR-802W, KHM-430)
It's a silver blob, you'll find it easily enough!
Aug 18, 2009 | Sony PlayStation 2 Slimline Console
Sony DVD player has a new laser assembly, but won't play discs.
Forbes,
I think you have taken on a great task. There are many steps to setting up the lasers before auto align can work. There are manual settings which need to be done. The manual will be helpful, however there is a knowledge of how to do the initial settings needed in order to get the unit just to recognize there is a disk waiting to be played. That happens in what is the initializing stage. If the settings are incorrect the unit won't even see a disc. I used to own a service center that was authorized by over 70 manufacturers. Laser replacement was never a swap and play thing. Alignment was always critical. And one more thing you should know. If the laser is too hot after you get it playing it will go bad quickly. You need a meter to check that as well. God luck Rob
Feb 27, 2009 | Televison & Video
PSP 2003 laser problem
Yes. The lasers are all the same the only difference is the size of the actual UMD enclosure which is only different with the phat (slightly thicker) just make sure its the right UMD tray.
Jan 20, 2009 | Sony PlayStation Portable (PSP) Console
164 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
