Question about McCulloch Garden
Chain oil feed is not working, Mac 335 chainsaw
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: What Oil is used for the bar & chain lubrication
Hi khipiercy...
You will use "Bar and Chain Oil" for your chain and bar lubricant...it is specially formulated to be used on chains and bars of chainsaws...
You can buy it at any Loews,HomeDepot, Ace Hardware, etc.
Please take time to rate me
Posted on Sep 22, 2011
My oleo mac chainsaw no longer feeds oil to the bar and chain. how do I dismantle it to find the problem?
If you have a fuel chainsaw Take an oversized old car or mower sparkplug with a long shaft to fix the piston or a piston stopper and with turn the nut to release in the same direction as the chain turns also the clutch. then you can replace the oiler.
Feb 22, 2016 | Garden
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
Change chain
Loosen and remove bar lock nuts and cover. screw tensioning screw to loosest point. wrap chain onto teeth of drive sprocket, then within grooves on bar. Be certain cutting edges are facing forward. Look at chain before removing. set bar with new chain to ensure the tension pin aligns with bar tensioning hole. Replace cover set nuts loosely. Tighten chain to about 1/4" out of groove when pulled on (wear gloves). Tighten nuts, spin chain to see it moves freely but does not hang free og bar groove. re-tension as necessary. Happy cutting!
Jan 04, 2015 | McCulloch Oregon 14" Chain for Mac Cat 351...
My chain oiler is not working on my MAC 335
Sounds like something is clogged. I recommend contacting your local service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jan 02, 2013 | McCulloch Garden
Hi khipiercy...
Sep 22, 2011 | McCulloch Garden
What is the correct fuel for a mac 335
Unleaded fuel mixed with good two stroke oil at a ratio of 25-1
Aug 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I need to know which oil type goes into the oil chamber for the chain on a mac 3200 gas chainsaw, not the mixture...thanks
There really is no exact type of oil that goes into the chain and bar oiler. Each manufacturer usually makes their own, but any chain and bar oil will work. It is a thicker type of oil unlike a motor oil. Just ensure that the bottle says "bar and chain" oil
May 02, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How does the oil pump work? What drives it?
Most saws today have pumps that are driven by the chain sprocket/clutch. Some may operate from the crankshaft on the clutch side. Some older designed saws operate from vacuum/pressure from the crankcase, ie. Homelite XL, STIHL 009, McColluch Mini-Mac.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 06, 2009 | Garden
Can't rememeber what fuel or oil it needs and how to start it
Start with a 40-1 mixture this should not hurt engine for a long time if you are just a casual user. The oil in the chain reservoir is chainsaw bar oil and I usually top off each time I refill the fuel. To start Turn on switch, close choke, hold throttle to open position, You may need to place saw on the ground hold down with foot in the handle while pulling cord. Once it tries to start place choke in mid position and try to start again. Once it is running place choke in full open position.
Apr 11, 2009 | McCulloch Garden
No oil getting through to chain on use
Hi
The oil feed depends on the rpm of the engine.More rpm results more oil.Check the oil line,the oil filter(inside the oil tank),the gear worm and the oiler:Clean the oil way.
cheers savumihai71
Dec 05, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
102 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
