Question about Refrigerators
My Ge Profile refrigerator (PSH23SGPABS) leaks water from the bottom of the refrigerator when the water dispenser is depressed. Also, the express thaw light in the fridge side stays on but I don't hear the motor running and the temp in the fridge and freezer fluctuates up and down even thought I have set each at a specific temp.
4 Suggested Answers
  • 1891 Answers
SOURCE: Fridge is clicking, everything in freezer is thawed
the clicking is the motor start relay . this needs to be replaced . if compressor is ok it will start / if unit is older it may have a bad compressor and will not start up . most units will start up . you can also use a hard start kit . appliance parts dist have these . hope this helps **** .
Posted on Mar 26, 2010
freetek
  • 5568 Answers
SOURCE: not cold
If the compressor seems to be cycling as normal, either the system needs recharged or the temperature controller has failed. If the compressor is running at all, it is probably OK.
Diagnosing it remotely is only guess-work, I recommend (if in the US) that you check with the local BBB for a trustworthy service company to assess your unit.
If a recharge is needed, this is not a DIY job since it requires opening a sealed system and soldering it shut after the coolant is at the proper pressure.
Replacing the temp controller might be possible but better done by a pro since the location of the sensor tip may not be easy to find.
Another (albeit less likely) is the failure of the defrost timer which could keep the heater on while trying to cool.
The timer is often located behind the lower trim grill and should be a small box with connections.
Some have a slotted shaft protruding from the case that can be turned with a common screwdriver.
Checking the switch contacts inside can be done by waiting until you hear the compressor running and then slowly turning the shaft until the compressor shuts off again; this would represent the defrost cycle.
If you advance the shaft another 1/4 turn and leave it there, after the compressor stabilizes again, it should turn on.
Mark the position of the timer shaft and then recheck a couple of hours later.
If its shaft has turned, the timer is probably OK.
They typically have either a 24 or 48 hours cycle so the shaft movement isn't easy to detect over a few minutes time.
Good luck-
Posted on Apr 22, 2010
SOURCE: My GE Profile side by
My GE Profile side by side refrigerator keeps going to express thaw mode and temp is way out of range. Any ideas on the problem?
Posted on Dec 05, 2010
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water leak under GE Profile refridgerator when using door water
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | GE Profile PCF25PGW Side by Side...
GE Profile TPX24...water leaking from under freezer side...water dispenser works fine, but ice maker not working properly. What could be the problem...and how do I fix it?! Thanks
i had the same issue twice. 2 suggestions 1) Remove the front grill at the bottom and you will see a plastic water line. Inspect it to see if it is leaking. Turn on the water dispenser when you are looking at the line. 2) pull out the refrigerator and remove the lower panel. Follow the plastic water lines to a solenoid valve and inspect the lines when you activate the water dispenser. water may leak from where the lines go into the solenoid value. if may be a simple fix like cutting the ends off the lines and reinserting into the solenoid valve.
Jun 14, 2009 | GE Profile TPX24PBDCC Side by Side...
Water is not dispensing but icemaker is working...
damaged water feed pipe at the bottom of the freezer door
Oct 22, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
