Question about MidiLand Audio Players & Recorders
MLI 168, are connected to the computer. Seem to be "alive", red lights are on but NO SOUND! Help!
    Brigadier General:
  • 3,513 Answers
Hi
If no sound is coming from the computer, start troubleshooting your problem. Make sure both your computer and speakers are plugged in, have power, and are turned on. If the speakers are plugged in but do not appear to have any power, plug them into a different outlet. If you are using a power strip and this is case, replace the power strip. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
Once you have verified that you have power to your speakers, test the sound again. If you still do not have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8" TRS cable) is plugged into the green audio output jack on the PC.
. If you are using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you are using outlet powered speakers and have a working set handy, replace the non-working speakers with the working pair to test. If you still have nothing, let's move on to software. But one tip first: (for geeks and beginners)
If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. If you've been messing around in the BIOS, you may have disabled your on-board sound if that's what you're using. If you don't know what BIOS means, you probably haven't been there and can move on.
Go to your desktop. Click Start > Control Panel > Sounds and Audio Devices > Volume tab. If everything is grayed out, go to step 8. If the "Mute" box is checked, un-check it. In "Device Volume" make sure that your volume level is set to a comfortable volume level for your speakers.
Click the "Sounds" tab. Under "Sound Scheme" check to see if "No Sounds" is selected. If it is, click "Sound Schemes" and a drop down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. These will be indicated by a small speaker icon located next to them. Simply left click the sound once, then click the play button. If you hear sound, congratulations. If not, move on.
Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Try this fix for reinstalling drivers. Click Start > Right-click "My Computer" > select "Properties" from the drop-down menu > Click the "Hardware" tab and then click the "Device Manager" button. Device Manager will open.
Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers" If you have a red X, right click the device with the x and select "Enable" from the pop-up menu. Test your sound at this point. If you have a yellow question mark, right click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Now, click the button "Roll Back Driver" to go back to the previous drivers that were functioning correctly. Restart your computer at the prompt.
As a last resort, you can uninstall and reinstall the device. Right click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If after doing all of the steps, listed here and you still cannot hear any sound from your computer speakers, contact a qualified computer technician.
Also check the bellow link to troubleshoot your problem:-
http://www.ehow.com/how_2225072_no-sound-problem-computer-speakers.html
Please get back to us if you have further query else please accept the suggestion.
Posted on Mar 23, 2011
How to build pentium 2
well first you need to get the following ..
  • AOpen HX45 Computer Case
  • Abit BH6 motherboard
  • Pentium II processor
  • 128 Mbyte, 100 Mhz, 8 ns, PC-100, 168-pin SDRAM
  • Focus 2001W Keyboard
  • Logitech M-S34 2-button PS/2 mouse
  • Four 9-inch cable-ties (also known as zip-ties) Garbage bag twisties will do, but won't look as good.
  • ATI Xpert@Play 98 with 8 Mbytes Display Adapter
  • AOpen 7277c 17" SVGA monitor
  • Panasonic 3 1/2" 1.44 MByte floppy drive
  • Maxtor 9136008 11.5 GByte, UDMA, EIDE hard disk drive
  • Toshiba SD-M1102 DVD drive
  • Additional IDE cable
  • AOpen FX-3D Plus ISA PnP Sound Board
  • MLi 699 Speakers
  • AOpen FM56-P PnP PCI V.90/K56Flex 56K MODEM
  • Windows 98 OEM
  • ATI DVD Player CD
Aug 13, 2014 | Computers & Internet
Where can I get a driver for my MLi 691H speakers? I am running XP.
The humming noise could be a earth loop problem.
This is caused by having the speakers/sub woofer connected to one power point and the computer connected to a different power point.
To eliminate earth loop problems, connect both the speakers/sub woofer and computer to only one power point. Connect all your equipment to one power point using a power board.
Apr 12, 2012 | MidiLand MLI-699 Computer Speakers
MLi-698 speaker: what voltage/wattage for the power supply?
Whatever is the voltage or MLi 698 Hi-Fi Sound Monitor ?
Mar 07, 2011 | MidiLand MLi 698 Computer Speakers
Not playing sound on my computer but plays sound on other things
the built-in speakers may have failed or you need to update drivers. please provide more details for us to follow up! what happen just before they failed?
Dec 20, 2010 | MidiLand MLi 691H Computer Speakers
My mli 699 speakers are not working . And I dont have the driver
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 12, 2010 | MidiLand MLI-699 Computer Speakers
I recently got a new computer & it has windows
If there is not a dedicated port for the sub, you are out of luck. Unless - the MLI sub can serve as the splitter
Jul 24, 2009 | MidiLand MLi 450 Computer Speakers
4.1 speakers on vista!!
Hi,Can you tell me the power supply (AC adapter) requirements for Midiland MLI 747 - 4.1 speaker system?
Apr 26, 2008 | MidiLand MLi 747 Computer Speakers
193 people viewed this question
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
