Question about Cycling
To help the poor - Cycling
    Problem Solver:
  • 7 Answers
To help the poor, save money on fuel costs by purchasing a dependable bicycle for someone. This is an economical way to travel, and It promotes fitness.
Happy Peddling.
Posted on Mar 23, 2011
93plymouth voyager failed smog high NOX check eng lite not on . But I did pull codes 34. 43. And 55. Egr is working but maybe not enough .can you please help.
too much oil??? or a bad oil seal or oil way
bad air filter
poor fuel mix
poor ignition advance...{vaccumes}
contamination in the fuel tank
bad inline fuel filter
poor back preasure {bad manifold or exhaust}
bad ignition system
etc.,..
all leed too a poor mix and bad nox
Sep 09, 2014 | 1993 Plymouth Voyager
What causes engine misfire?
misfire is caused by poor gas, bad injector, poor fuel pressure in some cases, bad spark plug, wire, ignition coil, poor compression. check the computer for codes this will help in diagnosing the problem.
Jul 13, 2014 | 2006 BMW 550i Sedan
I have 2 radios mp1000&990 the 1000 is working purfect but the receive on the 990 is very poor why is this what shall ido
I couldn't find mp990 or mp 990 radio anywhere on the web. If you're not going to do your own Google or DuckDuckGo search then you need to supply enough information so someone else can do the search to help you.
There are two basic reasons any radio has poor receiving
1. The receiver design is poor
2. Something has gone wrong.
If you have more than one mp990 and all are poor then the receiver design is poor. If only one is poor then the radio had been damaged.
If these are inexpensive FRS radios then chuck it and buy another. If it is an expensive radio try to find some place to have it repaired.
Good-luck
Oct 26, 2013 | Radio Communications
1999 mountaineer 5.0v8 awd a/t poor poor poor gas mileage 10mpg @ hwy speed 55mph ! What can be so wrong ? Help randallalt@aol.com thank U :-)
poor gas mileage with any vehicle is usually due to lack of maintenance.
options to try:
replace fuel filter
replace air filter
spark plugs
timing adjustment?
let me know if any of this helps
Sep 20, 2013 | 2005 Mazda B2300 Regular
Scope falls of tripod every time it is moved? Is this poor desin. Nothing seems to be broken
What type of telescope is it? Sadly there are a lot of poorly made "hobby killers" out there that suffer from poor optics and/or poor shaky mounts .
But knowing what type, model# & manufacturer would help narrow the problem down
You might also look to see if there is an Amateur Astronomy group in the area. They would likely be able to help.
Jan 04, 2013 | Optics
My printing is so poor
if your printer is printing poor quality photos i would recommend changing out the ink cartridges and probably getting a new hd printer
hope this helps!
Apr 09, 2012 | Zebra Office Equipment & Supplies
Rattling noise when starting and idling
It could be lose ehuset system parts or catalic conveter problem but itsan 86 thats 25 years old but i have an 85 ford ranger and it still runs great look for things that are lose or moveing around exhust system
Nov 01, 2010 | 1986 Ford F 250
I have a Nissan Frontier with accelerator & throttle problems. I have sensor codes p2122 & p2138. How do i fix this problem? Is it a self fix problem? HELP!
Throttle/Pedal Position Sensor/Switch "D" Circuit Low
P2122 - APP Sensor 1 Low Input
Probable Causes:
1 - Failed APP Sensor 1
2 - Open or short circuit condition
3 - Poor electrical connection
P2138 - APP Sensor Performance Condition Fault
Probable Causes:
I hope this helps you and thank you
Feb 14, 2010 | Nissan Frontier Cars & Trucks
Poor reception through wooded areas , and over hills. overall poor performance, will not work sometimes 1hundred yards in woods. advertise 26 miles! any help appreciated
Poor reception will be experienced in wooded areas and this is normal as the trees absorb RF energy. Range is dependant on conditions and terrain. Better range over water and open Country side, poor range in the middle of a built-up area. Low band better in hilly areas and UHF better in buildings. I have yet to find a pair of walkie talkies that will talk for 26 miles without a repeater.
Dec 14, 2009 | Midland Two Way Radio
Poor mic
whats the problem with your radio?
No Transmitted audio = mic cord faulty
Poor Rx / Tx power = poor SWR on the aerial
Dead radio = fuse or power supply faulty or protection diode faulty
Aug 20, 2008 | GE 35840GC3 2-Way Radio
Cycling Logo
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
