Question about Brother GX-6750 Typewriter
The correction is not working. does not wite out but the ribbon moves and it is not empty.
  • Brother Master
  • 3,594 Answers
The L/O tape may be installed wrong the dull side must face the paper.
DickyO
Posted on Mar 24, 2011
Not correcting & corrector ribbon not moving to correct
At this point almost all selectrics suffer from a case of the gummies.
it most likely needs a tech that under stands the selectric.
DickyO
Aug 28, 2012 | IBM Correcting Selectric Iii Typewriter...
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
How to install correction tape in the GX-6500 Typewriter?
Move carrier to middle with spacebar.
Open lid, remove black ribbon and old correction tape.
Gently pull new tape apart a few inches. attach take-up spool (empty one) to right post.
Pass through right ribbon guide, sticky side faces platen!
Unspool carefully thread through left ribbon guide.
Attach feeder spool to the left post.
Turn the right spool to tighten.
GL
Jul 04, 2009 | Brother Office Equipment & Supplies
How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
May 31, 2009 | Royal Office Equipment & Supplies
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Smith Corona SL575 typewriter no longer does corrections.
Be sure that the correction tape is a dry type general ribbon # T355 or equivelent.
DickyO
Mar 17, 2009 | Smith Corona Office Equipment & Supplies
Error code 754
It's very possible you are not installing the ribbon properly.
When loading a new ribbon on a Monarch printer, you must save the plastic ribbon core (it's butter yellow in color) from the previous roll of ribbon. The core is what the ribbon is wound up on.
Do not throw away this plastic core - you need it for the next roll of ribbon you load!
You have to move this now empty core from the back ribbon spindle and slide it on the front ribbon spindle. You then load the new ribbon on the back spindle and attach the ribbon end to the empty plastic ribbon core on the front spindle.
You CAN NOT just tape the ribbon to the front spindle. You must have an empty ribbon core to attach the new ribbon to. The printer will give a 754 error unless you have two plastic cores on the two spindles. It can also give a 754 error if the ribbon is not loaded properly, and also if you have a bad motherboard. There are no ribbon sensors, so that's never going to be a problem...
Jul 28, 2008 | Paxar Monarch 9850 Thermal Printer
Typewriter change correction tape
I just finished replacing mine..You must first remove the ribbon for the typing, this simply lifts off. Then you must place the side with the corrective tape on the left side and the empty end on the right. While doing so, make sure that the ribbon of corrective tape is being placed around the knobs( one on each side) to hold in place. Then feed through and wind up till all the orange has disappeared then replace the Typing ribbon and this should complete the replacement
Apr 07, 2008 | Office Equipment & Supplies
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
Brother AX-450 Electronic typewriter
Hellooo.
2 thing come to mind you may check.
First check the ribbon cartridge to see if it is empty..These are usually a one time ribbon...and has to be replaced when empty.
2nd make sure the cartridge is snapped in properly and seated, and also the printwheel lever must be snapped (pushed forward) in order for everything to be aligned. if the typewriter has a correction tape (white or clear) make sure it is not interfering with the ribbon.
Lastly the ribbon drive may be broken or out of adjustment. a minor repair.
Hope this helps...
Squipps
Jan 08, 2008 | Brother EM-430 Typewriter
Brother GX-6750 Typewriter Logo
327 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
