The Dell 2330dn printer is displaying the message "917.01 service transfer roll problem", and is not printing properly. Does this require a replacement of the printer drum, or some other part? Thanks, JB
jackboy
  • 2985 Answers
SOURCE: Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Posted on Nov 21, 2007
SOURCE: Dell 3100 CN replace drum cartridge
Google is your best friend
Posted on Jan 15, 2008
SOURCE: drum replacement message dell 3100cn
reset chips can be purchased from www.lasertekservices.com/contact_us.cgis for about $16.00.
here is a link for a discussion on replacement;
http://www.fixyourownprinter.com/forums/laser/45183
I hope this helps!
Posted on Sep 29, 2008
SOURCE: Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Posted on Jan 14, 2009
SOURCE: 1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
GOOD LUCK, EVERYONE!!!
Posted on Apr 16, 2009
How to reset counter of dell 2330dn?
Open door and hold down the cancel button.
Sep 06, 2012 | Dell 2330dn Laser Printer
917.00 transfer roll
The cuase is the HVPS card. Clean it or replace it.
Mar 30, 2012 | IBM Infoprint 1552n Printer
Printer displays 917.00 print error. seems to be transfer roller. changed the transfer roller same error.
The exact definition of this error is "Problem with transfer-transfer servo start error"... NOT the transfer roller. The service manual directs you to the Transfer roll service check.
The service check tests for proper operation of the HVSP, system board, and sensors.
The most likely cause of your problem is the HVSP ( High Voltage Power Supply ).
Change the HVPS and you should be good to go!
Feb 28, 2011 | Lexmark T640 Laser Printer
PC Life Warning on Dell 2330dn
Open front cover of printer as if you were installing a new toner cartridge. While holding it open, press and hold down the cancel button until the display says that the PC has been reset.
Feb 08, 2011 | Dell Office Equipment & Supplies
Dell 3110 laserjet printer, belt unit close to life
This message is displayed when the pagecount of the transfer belt is 80,000 (ish)+.
The rated life of the transfer belt in the Dell 3110/3115 is 100,000 pages.
After that pagecount the transfer belt 'expires' and no further printing is possible until the transfer belt is replaced.
Feb 03, 2011 | Dell 3110cn Laser Printer
Error message 917.00 service transfer roller. I replacedn the service roller but still the error message comes up.This is from the IBM Infoprint 1552.
A 917 transfer roll error code on all models at service level may
display if an incorrect level HVPS is installed in a printer that has the erase lamp assembly installed.
Check to make sure the correct level HVPS is installed.
Feb 11, 2010 | Office Equipment & Supplies
My Dell printer 2330dn is showing an error of 900.57 Firmware - what does this mean? It will not print
clogatto,
This error identifies a problem with the printers "internal language". Many times the firmware is just outdated and needs to be updated.
Since this firmware is vital in the communication of components, outdated firmware will cause miscommunication such as error messages or weird symptoms.
I would recomend having a tech update the firmware since you really need to know what you are doing.
Apr 17, 2009 | Dell Office Equipment & Supplies
441 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
