Question about Dell Office Equipment & Supplies
How do i get the imaging tool box for my v105 printer on windows 7
    New Friend:
Hi, the software disc when loaded onto the computer for my Dell V105 printer/scanner would not let me open the toolbox. I kept getting a message. Microsoft.NET framework version 2.0 error message. SIGNED in to Dell Website and downloaded http://www.dell.com/support/home/us/en/19/product-support/product/dell-v105/drivers
It now opens the toolbox and works great.
Posted on Sep 27, 2015
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: xp to windows 7 printer is ok but have lost the imaging studio
    Hi. Try downloading the driver available in the Lexmark website. The driver is for Vista operating system but it is compatible with Windows 7. Before downloading, check if your computer is running on 32-bit or 64-bit operating system by going to Start > right click on Computer > Properties. To download, click on this link to the Lexmark website. http://bit.ly/ajIYH7 . Then, click on the Microsoft tab on the center of the page. Download cjr4300EN.exe for 32-bit or download cjs4300EN.exe for 64-bit. Hope this resolves your problem. Good luck!
    Posted on Mar 12, 2010
    Tip
    How to Boot and Install Windows 7 from a USB (even without an ISO file)
    While searching in internet I found 3 ways of doing this thing. I will explain all of them here.
    1st Method: (The simple one) * Requires a valid ISO image.
    Download Microsoft's official tool to install Windows 7 from your USB stick.
    Links below:
    From CNET: http://download.cnet.com/Windows-7-U...?tag=mncol;pop
    MS Store: http://images2.store.microsoft.com/p...B-DVD-tool.exe - Microsoft Store Info Here.
    To install the Windows 7 USB/DVD Download tool:
    1. Click to open the Windows 7 USB/DVD Download tool installation file.
    2. When you are prompted to either save the file to disk or run it, choose Run.
    3. Follow the steps in the setup dialogs. You'll have the option to specify where to install the Windows 7 USB/DVD Download Tool.
    Note: You need to be an administrator on the computer you are installing the Windows 7 USB/DVD Download tool on. The tool requires the Microsoft .NET Framework version 2.0 or higher.
    2nd Method: (Reliable method, Supports multiple types of image files) Requirements:
    Now insert the USB drive, run UNetbootin, and select Disk Image as ISO( or select the type of image file of which you have).
    Browse your local drive for Windows 7 that you downloaded and click Open.
    Now Select Type as USB and choose the drive.Once done, it will look like a bit similar to the screenshot shown below.
    unetbootinmainwindows77.png Click OK and it will begin extracting all installation files to the USB drive. The whole process will take some time(10-15 minutes), so have patience.
    Once the installation is complete, reboot your computer. Now while your system is starting up press the appropriate button(usually F1, F2, F12, ESC, Backspace, or Escape) to bring up Bios Boot Menu. Change the startup order to boot USB by default, usually you will have to press F6 to move the selected USB device on top. Once done, save changes and restart the system.
    3rd Method:( Try this if both above methods are not working) Using Ultra ISO application.
    1) Download the free UltraISO trial by clicking on this
    2) Start UltraISO as administrator
    3) "Burn" the iso image to the USB stick by following these steps
    With UltraISO:
    - Open the image of Vista/Win7 with UltraISO
    - Under BOOTABLE tab choose WRITE DISK IMAGE
    - Choose your USB stick under "Disk Drive"
    - Choose a method (It's recommended to use USB-HDD+)
    - Press Write
    PS: Make sure to change your BOOT order in BIOS to boot from your USB drive first.
    on Oct 06, 2010 | Computers & Internet
    I have a problem with my 1Gb One Touch 4 external hard disk. I get error code Ox80070571 when I attempt to create a new folder or try to copy a file to the disk. I can see the images with Windows...
    windows 7 ultimate
    click start control panel system and security administrive tools then select view event logs then select administrive events in left panel across in the right you will see an error log with errors in red error was and at what time it occured you might be able to work your way through the problem
    click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
    right click to reinstall drivers
    if you can see your usb drive but its not working
    ports(com&lpt)right click update driver if this fails to fix the problem
    click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
    hope it helps
    Jul 21, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
    I have a Dell V105 scanner printer. I am able to scan a document as a picture, but no text edit is possible. I do also have ABBYY fine reader 6.0 Sprint. What am I doing wrong? I do have the Dell...
    Once you have scanned a text document you need to use an OCR (optical character recognition) program to convert the scanned image to text. This text document is then copied and pasted into a Word document to edit, amend and correct spelling mistakes created by the OCR program.
    There are freeware OCR programs on the Internet as well as commercial programs.
    Check out these freeware OCR programs from these WEB sites.
    http://www.simpleocr.com/Download.asp
    http://www.makeuseof.com/tag/top-5-free-ocr-software-tools-to-convert-your-images-into-text-nb/
    http://www.freewarefiles.com/category_3_41.html
    Feb 21, 2011 | Dell 924 All-in-One InkJet Printer
    I have a Dell V105 and i don't know what the buttons are for, i know which one the scanner is but i don't understand the others... help?
    1st - color copy
    2nd - black and white copy
    3rd (up arrow) - # of copies
    4th (4x5in) - prints a 4x5 of what is in the scanner
    5th - scan
    6th (x) - cancel current action
    7th - feed paper
    8th - power button
    For me, the buttons do not perform a function and all functions of the printer I've done on the computer through printing and through the Dell Imaging Toolbox program.
    Hope this helps!
    Aug 16, 2010 | Office Equipment & Supplies
    I have a Lexmark X5470 that will not work with my PC with Windows 7...It worked OK with XP. What can I do?
    a Windows 7 driver was never developed/released for the x5470 however the company did produce a Vista driver which they certified as Windows 7 compliant.
    You can download the driver here-
    http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_UK&question=X5470&productCode=LEXMARK_X5470&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X5470&searchid=1280592543355#2
    if you already installed the XP driver on your Windows 7 machine you will need to uninstall it with the following procedure-
    uninstall instructions for Windows
    Step Action
    1 Disconnect the USB Cable (where applicable)
    Locate the Start / Programs / Lexmark XXXX Series / Tools / Uninstall Lexmark XXXX Series shortcut. Image
    3 To start the uninstallation procedure click on the Yes button. Image
    4 Please be patient and let the operation complete. Image
    5 As indicated on the last screen, restart the computer by clicking Ok.
    //javaftper
    Jul 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
    Ihave Canon MP730 Image Class Printer. It seems to be incompatible with Windows 7.Please help me.
    Have you had your printer for awhile and recently upgraded your operating system to Windows 7? If so, you need to download a new printer driver (and software) from the Canon website for Win7.
    I recommend that you uninstall your printer and software before re-installing the software from the following link at Canon support:
    Canon MP730 Downloads
    Choose your operating system (Windows 7 or Windows 7 x64) from the drop-down box.
    Download the driver file and any additional software as needed.
    Run the driver installation routine and follow the prompts to re-install your Canon MP730 on your computer.
    Run the install routine on any additional software.
    I hope this helps!
    Mar 06, 2010 | Office Equipment & Supplies
    How to install dell v105 printer without the dis??
    If you don't have your disk, it is available on the dell support download website. The direct link to this printer driver download is available at this link:
    V105 driver.
    Good luck with your installation of your printer.
    Lolita
    Jan 17, 2010 | Office Equipment & Supplies
    I need a Mac OS driver for my Dell V105 Printer.
    To anyone with a Dell V105 printer and wanting to get it to work on Mac OS X 10.9.1. Dell's V105 printer is a Lexmark X2600 series printer. I suspect it's specifically a Lexmark X2650 Scanner/Printer. Download from Apple's support website the Lexmark printer drivers. Install and select "Lexmark 2600 Series" from the Scanners Printers in system preferences. I have not found a way to scan yet. But this got me printing.
    Jun 11, 2009 | Dell Office Equipment & Supplies
    816 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
