Question about Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer
My workcenter PE220 Xerox is displaying scanner locked and it is not printing or copying. What do I do?
  • 79 Answers
The manual says to unlock it. You will probably need the same password that you used to lock it.
Posted on Mar 23, 2011
The printer says the scanner is locked and won't print or copy. How do I Unlock it.
OK this answer you won't like,
For one there is no scanner lock on this device (not sure why the machine generates an error pertaining to that), 2nd and I assume you already tried turning it off and on and no improvement.
What the error really means to tell you is there is something wrong with the scan head movement or sensor. When you make copies there is a scanner head the moves over your original and captures that image, chances are if the reboot of the device doesn't fix this then your scanner head has come off the rails , kind of like a bicycle chain coming of your bike it must be put back on to move the bike...
You need to get the scanner head put back on the rails, This will require a Xerox trained service technician to repair, if you don't have a maintenance agreement on the PE220 you may want to call Xerox or the person you bought the device from to see what your options may be, may be too costly to have someone come onsite to repair ...????
I hope this helps...
Mar 08, 2015 | Xerox WorkCentre PE220 Multifunction...
Hi,i have Xerox Pe220,i am not able to copy as paper comes out blank but i can print from computer,i have replaced new cartridge but same result and put back the old cartridge,PLEASE HELP!!
Iffi,
Are you making copies on the glass or ADF? If you are getting blank copies using both the glass and ADF than your CIS(scanner) unit is bad.
Mar 22, 2011 | Xerox WorkCentre PE220
My xerox PE220 machine give LSU error. not any work in done plz give solution
plz solve my problume in my printer workcenter pe220 lsu eror and not working this time to help me plz
Dec 18, 2010 | Office Equipment & Supplies
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
This is an Issue with the Laser Unit. you can try to Plug it off from the socket and leave it for 10 min and try reconnect if this does not work it could be a genuine error and needs and technical visit
Aug 31, 2010 | Office Equipment & Supplies
Unlock scanner
under the scanner where you retrieve you printed papers on the left side twords the front there is a slide lever (which is the lock for the scanner).
Apr 29, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox PE220 workcenter shows LSU Error message.
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Ow to change resolution in xerox workcenter pe16 scanner
resolution for impression or copie if impression enter from propriété printer if copie you choose it from screen
May 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox pe220 cannot copy
i have the same problem too with my pe220. fortunately, i just purchased a new one which i planned to give to it to a relative, and I was able to figure out that the cause of the "function impossible" displayed.
the problem just occured this morning and I have tried downloading and updating the firmware too, clearing the memories, etc but cannot get the copier to work (can't print thru the pc also).
i then borrowed the new toner cartridge of the new pe220 and installed on my old one and i was able to print and copy again. the problem then is due to the chip memory.
the problem now is how to reset the serial eeprom chip in order to reuse the toner cartridge again.
hope this helps.
Feb 24, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer Logo
702 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
