Question about Hitachi 51F59 51" HDTV Projection Television
Hitachi 51F59A has 3 'lamps', blue, red, & green. No light coming from the blue, both others are lit
    Top Expert:
  • Hitachi Master
  • 14,161 Answers
Don't waste your money go and buy a new smart tv a 50 inch is around 400 and up. Wal-mart, Sam's Club. etc...
Posted on May 23, 2015
ctf1800
  • 4402 Answers
SOURCE: LCD BLOTCHES
I have never heard or seen this problem, i would change the lamp and if it's not it at least you have a backup lamp.
Posted on Jan 29, 2008
SOURCE: Hitachi 51F59A Color/Dark problem
Could be the blue CRT shorting out. I had the same problem but with red. Eventually it shorted out completely. If it is only 2.5 month old it should still be under warranty and they will fix it.
Posted on Feb 27, 2008
SOURCE: Where Can I Buy A Replacement Screen For Hitachi 51f59a Rear Proj
Hi, I have a brand new in the box screen for a 50 inch rear projection tv. I was going to put it on ebay but if this is what you need and what I have--well we can go from there. Email me with any questions you may have. Thanks, wrapper494@msn.com
Posted on Mar 18, 2009
tvtek
  • 1284 Answers
SOURCE: I have red (3) & green (1) spots on my TV
This is actually a memory error issue on the LCD driver panel board. This will require the repair from a Panasonic authorized servicer as there are no parts needed but they have to use a special reset tool that Panasonic provides to them. Call Panasonic and see if this is a covered repair since it was a well known issue. Please take a moment to rate my answer...Thanks..
Posted on Dec 04, 2009
Testimonial: "Thank you ... I have contacted Panasonic."
SD Tech
  • 14553 Answers
SOURCE: Hello: I have a 53" Hitachi Rear Projection
This model should use two of the STK-392-150 CONVERGENCE CHIPS---(some use 392-110 chips--both are the same but the 150 chips are higher output and last longer) both chips and any bad resistors around them (most are low value and easy to test) will need to be replaced and the set adjusted.
If magic focus will not correct the problem---the chips are bad.
This can be a do it yourself job if you have some skills; I can tell you everything you will need and how to do the repair (TOTAL PARTS COST FOR A PAIR OF THE CHIPS ETC ON EBAY WILL BE UNDER 25 DOLLARS) AND this is much less expensive than what any shop would charge you.
I have done over 1,000 repairs of this type and know from hands on experience what is needed and how to get the best results.
Let me know by responding to this post if you have questions and if this solution told you something of value rate it as "very helpful" as I do this here for free.
Posted on Aug 11, 2010
Yellow to green tent screen to hitachi tv 42v715
You have some reason to believe it will not?
Some history for you---several years ago Hitachi began along with others to have issues with the optical light engines.
With a mix of high heat from a lamp into the engine (it has a blue,green and red section inside---guess what? BLUE is the first place that gets the heat and is damaged----minus blue and you have red and green which equals YELLOW.
Several of their sets made about 6 years ago (research 50v500) had exact same issues and were settled in a class action lawsuit.
The issue can but does not always affect the entire screen.
The question really is: This set really worth the part and labor cost for the repair?
On that earlier model I replaced under warranty over 40 of the engines. Also Sony and others have had similar issues some of which were settled in court.
HOPE IT WORKS OUT FOR YOU.
Jun 11, 2012 | Hitachi 42V715 42" HDTV
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
What causes the picture to have a green tint
there are 3 color cathode in your TV red,green,blue cathode.The red and blue cathode might not working in your set that is why you have a green screen. Open the back cover of your TV you can immediately see the 3 cathode lamp at the back. Clean the lamp first using a clean clothe. Power up you tv and see whether the 3 lamps are lit. If lamps do not light up,check the circuit board where this lamp is connected re-solder all the components in this lamp. There is also an individual screen adjustment for the lamps it is located at the front panel and labeled RGB screen...try this first and let me know how it goes..
Apr 16, 2011 | Zenith E44W46LCD 44" Rear Projection...
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
Green screen
inside the light engine there is a red a green and a blue glass color filter.The heat from the lamp causes the color to burn off the glass.You need new filters .One is red one is blue and one is green.The lcd itself doesnt make the color,it is a black and white device.The colr comes from light shining through colored glass
Nov 11, 2009 | Hitachi 42V715 Rear Projection Television
Blue blob
Hello rivas_gab. Before I answeryour question let me explain a little how your tv works. You TV uses is a 3LCDtv that gets its picture from a lamp, the lamp produces a white light brighterthan the sun, the light goes through a square prism and is split 3 ways, eachgoing through a small LCD chip (blue, red & green). Then it travels troughthe light engine where the final picture is produced. The blue blobthat appears on the screen might be caused by one or two lcd chips that havestarted to get burn by the intense heat emitted from the light of the lamp. If that is theproblem you’ll have to replace the entire light engine, the other option isthat you buy the prism with the lcd chips, how ever that almost impossible becausenobody that I know sells them separately. If you decide tobuy, search buy part number, NOT model number, otherwise you’ll run the risk ofgetting non compatible parts. If you’re lookinga place to purchase look for dedicated tv part distributors (my personal recommendation:Discount-Merchant ). Happyhunting.
Dec 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 51F59 51" HDTV Projection Television Logo
209 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
