Question about Graco Nasalclear Aspirator - 1750335
There is no suction. I have made sure the lines are clear. There is good suction from the hole attached to the pump. The clear bulb seems to be a little loose & I think we are losing suction to the nose tube due to air leaking around the clear bulb.
I replaced my primer bulb on my craftsman weedeater an am not sure what line goes where on the primer bulb can you help also not the gas leaks out of carb hole where
In regards to which pipe goes where, it's simple. If you pump your primer bulb with the pipes off, one side will suck and the other side will blow. The suction side will link to the outlet on the carb. The blow side will link to the return to tank. The fuel line with the filter on it will link to the inlet pipe on the carb.
May 12, 2016 | Craftsman Garden
Why does the carb not prime with fuel?
Check the primer bulb. If it has a small hole or leak it will not generate the suction with which to suck the gas in to them prime the engine. And make sure that the top of the carb with the bulb is firmly attached to the rest of carb to prevent any base leaks by the primer.
Sep 20, 2015 | Garden
Eureka 439az has no suction. Beater bar spins ok.
First thing I would check is it has a attachment hose, take off the bottom of the vacuum. Where the beater bar is and look for where the hose goes through the bottom of the vacuum, it should look like a piece of plastic pipe. Make sure that pipe is clear if it isn't the vacuum won't work. I had that problem before with a different vacuum, clear the clog and should take care of the issue. Also if you take the hose off and put your hand over the hose attachment piece you should feel suction, if you don't good indicator that line plugged up.
You can use your fingers to clear it out, if the hole hose is plugged, if you have a snake a or a cable tie, or some flexible use that to snake out the bottom part of the tube. It might make a mess so I'd do it outside or in the garage.
See if that is part of your problem, otherwise it has a canister to catch the dirt, make sure all the vents and ports are clear going into the canister .
Sep 02, 2013 | Eureka Vacuums
My Kreepy Krauly won't move. I've checked the hose for holes and also replaced the vinyl suction cup on the bottom but it won't budge. Doesn't appear that there is much suction. Could it be something...
Yes, it could. Check the filter and pump for debris. This could severely restrict movement in these pool cleaners. Also, check the flaps of the Kreepy Krauly for debris. Also, check to make sure that the main drain and ALL suction lines, except the one the cleaner is attached to, are closed. This might also be why you have a lack of suction. My final suggestions would be to check the return line water flow and make sure that it is strong enough.
Dec 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krauly seems to have good suction, but moves very slow. I usually hear a tic,tic,tic,tic, But, lately it has been tic....tic......tic Very Slow
Try these suggestions to get your automatic pool cleaner working properly:
• Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached.
• Check for debris in the filter or pump basket.
• Check for debris in Kreepy Krauly’s flapper. Debris may prevent flapper movement or restrict flow.
• Check the hose to ensure there are no leaks.
• Check the vacuum connection. It should be submerged so no air enters the system.
• Check the pump basket lid for looseness, cracks, and worn or missing O-rings.
Jul 28, 2010 | Pentair Kreepy Krauly Inground Automatic...
Intex 633 lost suction
I have seen a common problem when customers change / clean their filter is that put the DRY clean filter in the skimmer box or filter holder and sometimes it can cause an "air lock"
Just take your garden hose put in the intake outlet of your pool and turn that baby on....If you start seeing air bubbles on the discharge end of the line most likely that was your trouble.
If the problem still persist then at that time look into pump repair / replacement.
Good Luck!
Jul 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
Suction line replacement
we cut a 12" hole.
David
May 23, 2009 | Pool & Spa
72 Pontiac GTO, been sitting for 8 years. I can't
You hit the nail on the head. Chances are the sending unit filter "sock" is clogged. Most of the time you can clear it by blowing compressed air back through the tank.
I would however, inspect the suction line from the fuel pump to the tank for rust obstruction and hoses for de-lamination.
Disconnect the line just before it goes into the tank and try to blow air through it just to make sure it is not rusted shut.
Good luck, let me know.
Regards,
Mar 23, 2009 | 1988 GMC S-15
Vacuum is losing suction
There are a couple of things you can do and it depends on whether you don't have suction from both the wand and the bottom of the
machine or just from one side:
1) First check the suction of the machine to ensure that the motor is still good - remove the canister and look for the two
openings/holes on the spine/frame of the machine - put your hand in front of the hole on the LEFT (higher than the hole on the right)
- if there is suction, continue the troubleshoot instructions, if there is no suction your motor may be damaged - call the Dyson
Helpline, they'll set you up with a repair with the closest authorized dealer in your area.
2) Check for blockages from the bottom of the machine. Remove the:
(i) U-Bend (stand behind the machine and look next to the right-hand-side wheel, it's attached with a rectangular clip next to the
long gray hose - push the clip and pull the U-Bend off, make sure its clear - if there's a blockage remove it and continue with the
blockage check to ensure that the entire machine is clear)
(ii) AI Valve (stand behind the machine and look above the right-hand side wheel, it's attached with two buttons on either side of the
AI Pipe/Valve - push the two buttons and pull the pipe up and off and make sure there is clear - if there's a blockage remove it and
continue with the blockage check to ensure that the entire machine is clear)
(iii) Refit the internal hose on the bottom of the machine between the wheels and make sure it isn't torn and has no holes in it and
that there is nothing clogged inside it - to refit the hose: Pull it off where it sits next to the wheel first - make sure that the
gray piece of rubber is still on the hose (if it isn't, pull the gray piece of rubber off the hole and reconnect it to the hose by
twisting it back on) - next, twist the hose off where it connects to the brushbar - inspect the hose and make sure you don't have any
holes in it - put it back on by twisting it onto the side of the brushbar first - then line the gray piece of plastic end up with the
hole next to the wheel and push and twist it back over the hole. Bring the machine back upright and test it
3) Check for blockages in the wand. Remove the:
(ii) Wand - take the wand off the back of the machine - put one hand on the wand handle and one hand on the gray hose - pull the
handle and push the gray hose down, you'll see a metal rod being exposed, push the hose until it clicks into place - press the
half-moon shape button with a picture of a lock on it (found on the solid gray plastic end of the flexible hose) and separate the wand
competely - point the wand into the air or at a source of light (please don't point it at the sun) and look through the metal rod part
- the handle is bent but you should still see some light coming through the other end - if you don't, there is a blockage in the wand
- use a long object like a stick or a metal hanger to remove the blockage
(iii) Hose - no need to remove it - just stretch it out and make sure that there are no dark spots in the hose (those would be
blockages) - you can also through the top of the hose - if you don't see the ground at the bottom there is a blockage in the hose
4) If no blockages are found on the machine at all:
(i) wash the filter in cold water and leave it out to dry for at least 24 hours
(ii) blow out the cyclone from the bottom (open the door on the bin door - you can now look into the cyclone) - blow it out with an
air compressor or a leaf blower
(iii) Wipe all the small holes off on the cyclone with a dryer sheet
When the filter is dry, test the suction again. If there still is no suction on the machine, call the Dyson Helpline, they'll set you
Feb 21, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Graco Nasalclear Aspirator - 1750335 Logo
546 people viewed this question
Top Graco Baby Care Experts
ray gallant
Valeriy Bacherikov
Level 1 Expert
ReGina Lewis
Level 1 Expert
Are you a Graco Baby Care Expert? Answer questions, earn points and help others
