Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Bad Carb After starting the engine on my gas powered 31cc 2-cycle trimmer, I cannot get any power. Every time I pull the trigger to give it a little gas, the engine dies. It will idle ok, but then quits when I give it gas. I have primed it plenty and there is gas in the thing.
  • markneumann Aug 12, 2008
    on mine, the priming bulb goes flat, it can't **** in any fuel into the carb. When starting, it quickly runs out of fuel. The guy at the shop says it is because of old fuel gumming up the lines.
    I am going to try to clean the carbuerator.
  • Anonymous Aug 15, 2008
    I've cleaned and blown through the carb but it still fails in the same way as yours runs ok with choke and on idle I have also changed the spark plug but that was no good either. There has to be a blockage somewhere but I can't find it
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 29, 2008
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Carb set screw were change and stalled won't start
Try 1 turn out each. Open a quarter at time trying to start. One is for mixture at idle. The other is hi speed. Adjust each for best performance. This is a general rule and not specific to model.
Dec 07, 2013 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Where is the fuel mixture screw on poulan pp133
On the carb. Low for initial and high for top end. Start with both at 2 1/2 turns out. Then adjust low when you pull the trigger to eliminate hesitation. Then floor it and hold while you adjust the high
Feb 16, 2013 | Poulan 25cc 2-Cycle Gas Powered String...
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Pull string comes out 1/2 to 3/4 of the way and stops...doesnt crank the engine. What needs to be done?
pull off the recoil housing and see if the motor turns fully with out it if ok pull the rope off the engine does it pull all the way out
Mar 29, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
My Troy Bilt TB20CS won't start. Can you give me any do it yourself advice, such as rebuilding the carb? and where to find discount parts? The machine is only a couple years old and with very few hours of...
I have the same tbs20cs it starts ok but it will die when I shift to run. I looked at the fuel lines and they fell apart in my hands perhaps due to the ethanol in the gas. I cleaned the carb. with a good quality cleaner but no diff. please help solve why it dies.
Oct 14, 2010 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
How do you change the pull rope on a poulan 31cc gas trimmer
You have to take the unit apart. Seperate the shaft from the engine. Then take the engine off the back side. This will allow access to the starter spool, where the rope goes. If you get that far, be careful when you wind the spring. Good luck...Lee
Sep 25, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Aug 10, 2009 | Troy-Bilt Garden
Engine stalls when giving gas
Make sure you have the carb. fuel line on the correct side of carb. Not on primer bulb side.
May 14, 2009 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
410 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
