Question about Samsung 225BW LCD Monitor
Samsung 225BW monitor flickers it has been used quite extensively has a good number of years on it been used for gaming mostly im assuming it probably needs the lamp/tube is this possible to be the culprit and how much can it be the cost of the lamp alone?? thanks much
  • 11,361 Answers
SAMSUNG this old is more likely to have bad DC filter caps by now, look for caps with domed tops, also replace them in a set using good caps with low ESR and 105c rating.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 23, 2011
  • 43 Answers
Flickering can be a couple of different things:
Try a different wall plug, to rule out RF interference.
Replace the video cable and make sure it is not running parallel to any other cables.
If you are using VGA, use the DVI port.
Make sure you are running the monitor in it's native resolution (I think yours is 1680 x 1050) and are using the newest drivers for your graphics card. You can also try down-clocking the card and double-checking to make sure you are running the refresh rate at 60 Hz.
Unfortunately, replacing the backlight (unless you find one on eBay and do it yourself) is probably more expensive than buying a newer, bigger LCD with a faster response time.
Testimonial: "great help much appreciated will try those options thanks"
Samsung 225bw
Here is a link to a repair guide that may help you get it going again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
May 13, 2012 | Samsung 225BW Monitor
I have a SyncMaster 225bw, approx 3 years old but havnt used it much in the last year and a half. it started having a problem starting back up it seems. if i can get it to stay "lit up" it will...
This type of monitor problem is usually cause by a failure of the capacitors in the power supply board. What is happening is the power supply is not starting up correctly so the back lights are not coming up to full brightness. Here is a link to a repair guide that will show you how to dis-assemble the unit and repair the power supply board. http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
If you can do a little soldering then you can do the repair yourself.
Apr 15, 2011 | Samsung 225BW LCD Monitor
How to open a Samsung 225bw besides just removing the screws?
Here is a link to a repair guide that shows how to dis-assemble the unit.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 12, 2010 | Samsung 225BW Monitor
Monitor will not come on. Power light just flashes.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 13, 2010 | Samsung 225BW Monitor
I have no blue light at the power button for my Synchmaster 225BW
The power switch is a momentary tactile switch. If you want to fix it, you will have to turn it off and look at the size of the switch to try to find the replacement for it. Not much you can do but open it up to find the cause of the problem.
http://www.badcaps.net
Apr 17, 2010 | Samsung 225BW LCD Monitor
Need to replace all capacitors in my 225BW. Need
The 225BW monitor uses the same capacitor kit that the 214T monitor uses. You can order the repair kit at:
http://www.ccl-la.com/LCDrepair4.htm The kits run $12 including shipping. If you don't want to do the repair we do offer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 31, 2010 | Samsung 225BW LCD Monitor
Moniter is flickering, just bought a new video card, have had the moniter for over 2 years , any solution?
You can disassemble it check it for bad capacitors. Other than that you can check on ebay to see if anyone is selling the boards for that model. Sometimes you get lucky and find someone that has the same model with a broken screen.
Dec 02, 2009 | Samsung 225BW Monitor
Monitor comes on dimly then goes off
The most common cause of dim displays on this unit is a failure in the back light power supply. This problem can be fixed if you can do a little soldering. Here is a link to a repair guide that will show you how to dis-assemble and repair the power supply board.
BuddyMc
Nov 17, 2009 | Samsung 225BW Monitor
Hi, i have Samsung SyncMaster 225BW monitor and while using Microsoft word it stop working. On off button blinking with blue light.. However when i plug/unplug the video cable nothing happens. Regards...
There r problem with your CPU not from Monitor might be any hardware failure at that moment.Pls restart the system after that if display is coming or not if display is not coming might be RAM chip is faulty replace it with goods one.If display still not coming then problem with your Motherboard.pls get it repair by vendor.
Nov 17, 2009 | Samsung SyncMaster 203B LCD Monitor
Samsung 225bw display with NO VIDEO and flashing power button
A flashing power light and no picture is a sure indication of a shorted power supply board. There are parts called capacitors that fail and this causes the power supply to continuously shut down and restart over and over, hence the power light flashing. If you can do a little soldering then you can repair the unit. Here is a link to a service guide showing how to dis-assemble the monitor and repair the power supply board.
I hope this helps, if so please ratre my solution.
BuddyMc
Nov 22, 2008 | Samsung 225BW Monitor
Samsung 225BW LCD Monitor Logo
447 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
