Can a bad battery cause the screen to turn off after a couple of minutes use. Ive inserted the recovery cd and hooked a external monitor up to the laptop and all is fine so far. prior to that the screen would flicker during the set up and then it would go black but using a touch you could see the data was still on the screen and you could still operate just in darkness with the aid of a torch.
  • 158 Answers
I dont think its a battery from the sounds of it, you may have problems with your LCD since its fine on the external
Posted on Mar 23, 2011
My laptop Gateway ml6720 has a black screen Ive replaced the battery and power adapter no change. The fan comes on and it sounds like it boots up but no screen.
Sounds like either the screen or the video adapter has gone bad.
Do this: Connect the computer to an external monitor (there is a SVGA plug on the side of the computer. Be sure when you turn it on that you press teh Fn-special function key combo that switches the video output to the external monitor. If the external monitor works, then it's your computer's screen. Possibly the inverter. If the external monitor shows nothing, then it's the video card (which may be built into your motherboard).
Oct 05, 2011 | Gateway Computers & Internet
My toshiba satellite m305 s4819 had a colored lines on the screen so I thought it was simple to fix so I open the screen and tried to open the inverter jack but it was small and hard to I used flat screw...
1) The FIRST thing you do when working on a computer, Desktop or Laptop, is to Remove Power.
2) The SECOND thing is to observe Anti-Static Precautions.
You need to disconnect the Video Cable, and the Inverter, FROM the motherboard.
This will ensure that the LCD screen, Backlight, and Inverter are taken out of the system.
You may have shorted across enough with the screwdriver, to just damage the electronic components on the Inverter.
With it connected in the system the computer will not turn on.
But I also want to take the Display Assembly, out of the 'equation' temporarily.
Of course the damage may be more extensive. Diagnose one step at a time.
Laptop off, monitor off; connect a VGA monitor to the VGA connector on the laptop.
Turn the monitor on, allow it to 'warm' up.
Turn the laptop on. If graphics do not automatically show up on the external monitor, press the Fn key, and hold it down, then tap the F5 key.
The F5 key is the toggle-over display key.
You can have;
1) Just the internal monitor of the laptop,
OR,
2) The internal monitor AND the external monitor,
OR,
3) Just the external monitor.
This is why you may have to tap three separate times.
Post your findings back in a Comment.
Regards,
joecoolvette
Sep 24, 2011 | Toshiba Computers & Internet
WHen I hook my laptop to my external HP 22" monitor, using my HP docking station, it recognized the monitor but the externalk monitor stays dark. Every so often it will flicker and then give the...
no laptop stated ok W7 OS, nice to know.
hopeless?
nor external model screen stated
try a different external screen
any shop can fix it, ask them
no need to ship anything
get it checked out by a technician
we can test all 3 parts and tell you whats worn i minutes.
i can not understand your post
try to be more clear
does local LT screen work ok
does using a known directly connected screen (VGA)
on the LT you must turn on external screen using the fn hot key
the the external works,. do so, now
if both internal and external fail the LT is bad, guess, bad GPU chip
if only external fails, try a known working external screen
if that works your external is bad.
the docking is last, and if only it fails, then ITS BAD.
Mar 14, 2017 | HP Pavilion DV6910US Laptop
I have a light pink Sony Vaio VGN-CR510E and i've had it for a little over two years now. The screen has gone grey/white and will only return to the natural screen when the tops of the screen are squeezed,...
I wouldnt say beyond repair, if you were able to compress it and the screen would appear normal there is a connection problem, your monitor has small connections making it work one happens to be an inverter. It could be that the connection is loose, the bad thing about that is if its loose there is a chance it could cause a short which in return you will need an inverter or whole monitor.
1. try hooking it up to an external monitor, you need a vga or dvi cable and try hooking up to a projector or another monitor, if that doesnt work its your video card. unfortunately either fix is somewhat expensive. Good luck and please vote thank you.
if you have have hooked up an external monitor before here are some instructions
1. make sure the power is off
2. plug the vga cord to your laptop and to the external monitor, 15 pins normally blue or back has 15 little holes ive seen some that are pink.
3. turn both on
4. you may have to hit a function key thats the fn button plus (on mine is f4 small rectangle with a line on each side of it .
5. if the external monitor works then your monitor or the cables to your monitor are bad
6. if the external monitor doesnt work its your video card and you will need a new motherboard if the card is integrated.
Feb 18, 2011 | Sony VAIO VGN-CR510E/L Laptop
The screen is black but the computer is running,
Try to hook up with external monitor in order to check if your lcd monitor have problem. If the external monitor have display that means your lcd monitor is defective. If the external monitor having no display in that case you have to check your system ram or memory or clearing your bios or cmos by removing your cmos battery for 5 seconds then insert again the battery. Then try again turn on your computer. Good Day
Nov 30, 2010 | Toshiba Satellite A215-S5837 Notebook
Help! My Dell latitude d800 beeped than the screen went white. Than turned aqua so I turned it off for a half hour. When I turned it back on the windows screen pop up. Then it went blue and started...
i think there is problem with your video driver or lcd
you should hook your dell with external monitor and look out for error and then download a recovery cd from following link
Windows Vista Recovery Disc Download — The NeoSmart Files
Burn it to cd and boot your laptop with this cd and it will repair your windows
Jul 21, 2010 | Dell Latitude D800 Notebook
Hi, my laptop powers up but no screen appears. just the left two blue lights go on and then power light stays?
Turn it off, unplug it, remove battery, then press and hold power button for 5 full long seconds. Wait a couple minutes, put battery back in, plug in and turn it on.
This should fix the problem. If it still persists, check memory chips or try removing just one and see if that helps. Bad memory chips can cause this. But try first solution first.
Apr 17, 2010 | Dell Inspiron 1525 Notebook
Unable to start the notebook
No screen usually means bad inverter or bad Lcd.Hook up to an external moniter and see if you have video.If you do then your lcd has gone out.
Apr 04, 2010 | HP Pavilion dv2000t Notebook
Phone turns off every couple minutes and then turns on by itself.
What I would do is turn it off completelly for a few minutes. take out the battery and let it cool down for a few minutes. If you have a battery that if fully charged put it back in and turn on your phone. if your battery is not totally charged, charge it. A phone whose battery is not fully charged may cause your phone to flip out. sometimes it's also water damage to the phone that causes it to turn off on its own.
Water damage happends from body heat, from taking it to the bathroom when you're in the shower, or from putting it directly in water.
Hope this helps.
Mar 25, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Black Screen
try hooking up an external video source. Check to see if the computer is actually booting up. if the computer boots up, then the LCD invertor or Backlight of the screen is bad, need to be replaced.
If the computer does not boot up after hooking up an external video source, then most likely your motherboard is bad!
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 29, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
