Question about Xerox Phaser 8560MFP Laser Printer
I have a problem with my printer 8560mfp. i can't reset, after one problem printing i put the button one time ON one time OFF but i have always problem
  • 79 Answers
Try holding down the power button for 5-30 seconds (until the printer turns off)
Posted on Mar 23, 2011
My printer xerox phaser 8560mfp is printing landscape 1/2 page instead of a full size portrait from a pdf file. How do I get that fixed? Thanks!
You need the new driver. Goto the Xerox website and download the latest driver and save it on your C: drive. Goto Devices and Printers and remove your existing Xerox 8560MFP. Reboot your computer and go back to this screen and click on "add a printer". When you get to the screen "Install the printer driver" you will see Xerox 8560MFP PS highlighted DO NOT CHOOSE THIS! (you will simply be installing the same driver from Windows 7 back). Instead, Click on "Have Disk... and navigate to where you saved the driver. Choose that one and finish the install.
May 20, 2011 | Xerox Phaser 8560MFP Laser Printer
I just got a 8560MFP and I am running win 7 64. I can not get the printer to print in colour only black and white, and advise/help?
in your printer driver, Start/printers & Faxes.. Right click the printer Icon for your 8560 and goto properties.
Goto Advanced Tab and then Printing Defaults..
Make sure the Black & White printing is Unchecked.
Jan 14, 2011 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP: When in sleep mode, the printer still wakes up to do a warm up test and then goes back to sleep. How can I turn this off?
Look in the setups.
It might be a good idea to print out the setup sheets. Look under sleep mode and set the time accordingly to what you want.
Alternatly go to the WWW.xerox.com website for assistance.
Good luck.
Oct 03, 2010 | Xerox Phaser 8560MFP Laser Printer
Wont copy, displays 09,038,46: 14444
www.support.xerox.com/go/results.asp?...8560MFP...
This is a fault of the inkloader. A broken ink is not tripping the sensor, or it is out of ink.
Turn on printer. When logo starts, press and hold the info and back buttons until it says entering diags.
Go to functions menu, scroll to reset IRC counter,enter, and then exit diags. Printer will boot to ready.
Well when the logo is moving before it centers is when you hold down the back and help buttons and it should reboot in service mode, usually it takes it a second or two to start the process. So you can try that again or go into service mode the way you did before. Once in the service/diagnostic mode you need to scroll to the bottom to the function menu then reset the IRC counter in the sub menu and you should be good to go. You were almost there before. I have to do one today so if I notice anything different than the instructions given to you I will post back but Ive done it several times and everything sounds right.
Master link below. http://webcache.googleusercontent.com/search?q=cache:RP4PhFss0oMJ:www.fixyourownprinter.com/forums/printer/62877+Xerox+Phaser+8560MFP/D+error+09,038,46:+14444&cd=5&hl=en&ct=clnk&gl=nz
Jun 10, 2010 | Xerox Phaser 8560MFP Laser Printer
Receive message Printer status is not available at this time when trying to print
Getting "printer status is not available at this time" when trying to print
Apr 09, 2010 | Xerox Phaser 8560MFP Laser Printer
I have a Xerox 8560MFP printer with the following error code. 07010.43:39050 Any help would be appreciated
Your print head is stuck. Either the print head block has gotten ink in it and will not allow it to tilt, or the print head wiper is tacked, ( stuck) to the print head not allowing it to move properly.
Jan 11, 2010 | Xerox Phaser 8560MFP Laser Printer
What is walk up feature on printer?
It is a print job that was sent as a walk up print that "sits in the printer" till you tell it to come out.
prass the start button I think.
-Carl, please let me know if this helps.
Jun 27, 2009 | Xerox Phaser 8560MFP Laser Printer
Machine will not print double-sided documents
Try resetting the NVRAM from the diagnostics screen.
Apr 09, 2009 | Xerox Phaser 8560MFP Laser Printer
I have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Mar 11, 2009 | Xerox Phaser 8560MFP Laser Printer
Printing Black & White
sure..but you need to set that in the settings of the documents printing under default(use greyscale).
Try this link for more Printer Resources
Aug 19, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
114 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
