Question about Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 6, machine is beeping and the door won't open
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
What do's f16 mean on the bosch classixx 6 1200 mean
F16 is a door fault, could be the door is not tightly closed before pressing start, the lock is faulty so the machine is not registering that it is closed or the wiring connection to the door lock is loose.
Apr 10, 2013 | Bosch Washing Machines
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machine will bo start
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
May 26, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
May 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
May 19, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Got the Bosch Classixx 6 1400 Expresswashing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks!
May 14, 2010 | Bosch Classixx WFO 2466 Front Load Washer
I have the same problem - Did you mange to sort it out?
Mar 23, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Got the Bosch Classixx 6 Express 1400 washing machine cant
Feb 22, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
133 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
