Question about Dryers
Maytag neptune dryer; when it turns on, controls don't work. unplugged and replugged and eventually it is able to be controlled. after 5 minutes, turns off and same problem occurs
  • 96 Answers
Run diagnostics. remove bottom front panel and retrieve diagnostics sheet from inside and follow instructions
Posted on Mar 24, 2011
My dryer won't turn on. There is a red light saying something is locked
Hello my name is Heath it will be my pleasure to assist you unplug the dryer for 30-60 minutes replug the dryer in or turn the power off by the breaker and turn the breaker back on by the plugg or the breaker.
Apr 05, 2010 | Maytag Neptune MDE6700A Electric Dryer
Our maytag Neptune Dryer is showing 8.8 on the display. It has done this in the past and we have had it looked at and they could fine nothing wrong. Now it doesnt work again.
usually thats indicitive of a powerfailure
try unplugging the unit for several minutes
your trying to clear the e-prom
if you cannot clear it that way
more than likely you will neeed a new control
Oct 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
May 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune gas dryer beeps.
NO RESETS OTHER THAN TO UNPLUG THE DRYER FOR 5 MINUTES, THEN RECONNECT POWER. ON ANY ELECTRONIC CONTROL, THIS WILL RESET THE CONTROL'S MICROCOMPUTER. IF THAT DOESN'T SOLVE THE PROBLEM, THE TOUCH SWITCH MAY BE FAULTY.
Apr 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
Dec 23, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Timer problems
Yes it probably is but check the keypad also.It could have a short in it.
May 26, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Follow up on an earlier problem
I have had the same problem over the past several months. Typically it would clear itself out (clear 8.8. on display) after several minutes. Today it reoccurred but this time it would not clear. I knew it was a problem with the control board. So I removed the control board and discovered that the capacitor for the 5VDC power had ?popped?. I replaced the capacitor and every thing worked! Hope this helps.
Apr 14, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
