Question about HTC EVO 4G Smartphone
Installed applications on HTC Eco cannot be deleted by Any means available.
    Problem Solver:
  • 19 Answers
If your phone is stock or unrooted. You will not be able to remove the stock sprint apps such as Nascar, Football etc. To remove these programs you will have to get superuser access also known as root.
Posted on Apr 06, 2011
My htc mobile was very slow operating
There will be reason that you have installed too many apps in the mobile. Simply you need to uninstall apps which are not required any more. Also scan your mobile through AVG antivirus application which is easily available in Android Market.
I think your query shall be resolved. Thanks!
May 30, 2013 | HTC Desire HD Cell Phone
How to install softwares on htc wildfire
If you have application files (*.apk) on your computer, you can use HTC Sync to install them to HTC Wildfire S. It is strongly recommended you install only applications that you trust.
Before you begin, make sure that HTC Wildfire S is set to allow applications from your computer to be installed toHTC Wildfire S. To do this, press howtoimage.aspx?id=88185 while on the Home screen, tap Settings > Applications, and then select the Unknown sources check box.
  1. On the Device panel, click Overview.
  2. Click Application installer.
  3. Browse for the application file on your computer, and then click Open. The installation process starts on HTC Wildfire S.
  4. Check the screen on HTC Wildfire S to see if there are additional instructions to complete the installation.
  5. After installation is complete, you can click Disconnect.
  6. Safely remove HTC Wildfire S as required by your computer's operating system.
Jun 01, 2012 | HTC Wildfire
How to uninstall default apps
Can't. If they come on the phone when you buy it, they are a part of the default software. It's annoying yes, but that's just how they do it. The way the phone comes is usually how it stays.
Sure you can add and delete your own apps, but default programs are just that. Default and a part of the internal system
Aug 24, 2011 | HTC Droid Incredible Cell Phone
The application screen process com has stopped unexpectedly. always shows this message
Something you installed or changed in the system might be causing this problem.
In order to get rid of it try to reset it.
Here, we show you how to hard reset the HTC Desire with step by step instructions.
Please note that all data will be deleted from the HTC Desire as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
  1. Turn the power off. If your HTC Desire is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the HTC Desire. Once the wipe is complete, the phone will reboot to its factory fresh state.
I hope this helps.
Mar 11, 2011 | HTC Desire Cell Phone
How do you get the upgrade the htc hero to 2.1
Getting Started
Before you run the ROM Update Utility (RUU), make sure you have done the following:
  • Backed up the data on your device.
  • Standby or hibernation mode of your PC has been disabled.
  • Close all running applications on the PC.
  • Set aside approximately 25 minutes to allow the device to update.
  • Charged the battery to at least 30%.
  1. Download HTC Sync for Android.
    Install the HTC Sync software on your PC if it is not already installed. This software was included in your HTC Hero gift box. The minimum required HTC Sync version is 2.0.28. We have HTC Sync for Android 2.0.40 available for download; newer versions might be available from www.htc.com.
    HTC Sync for Android 2.0.40 (39MB)
  2. Download the Hero 2.1 MR Upgrade executable file.
    Hero 2.1 Upgrade (113MB)
  3. Connect your HTC Hero to your PC.
    Use the supplied USB cable.
    If the HTC Sync application appears on the screen of your PC, you may simply dismiss the wizard by pressing the Cancel button.
  4. Run the Hero 2.1 MR Upgrade RUU file.
    Follow the on-screen prompts to install the update for your HTC Hero
WARNING: During the upgrade process, do not attempt to make/receive calls, press any buttons on your device or disconnect the device from the USB cable as this will stop the update and your device may be rendered inoperable!
If you have a problem with the connection between your device and PC be sure to check the connection type in your device. This can be done in the device via Settings -> Connect to PC. Ensure that HTC Sync is selected.
Mar 09, 2011 | HTC Hero Smartphone
How do I delete the game applications that I have downloaded and no longer want to store on my mobile.
Good day,
To uninstall unwanted applications on your HTC Android do the following:
Click on Setting and locate Applications
Click on Applications.
Select Manage Applications
Click on Manage applications
Browse until you find the program you want to delete.
Click on the application.
You will see an Uninstall button.
Click on it to start the uninstall!
Hope this helps!
Feel free to let me know if this was useful!
Kind Regards
Dec 02, 2010 | HTC Cell Phones
How to uninstall apps like..skyfire ,openweb radio
You just have to copy the .cab file (which is the application installation file) to either your phone internal memory or the memory card (if it is inserted, that is), and tap over it. You will, then, be prompted to install the application either on the internal memory or memory card. Then, it should be available under 'Start > Programs' (depenidng on what you have installed, it might show under 'Start > Settings'), ready to be launched. After the installation, you are free to delete the .cab file, if you want (of course you can keep it there, for future installations, if something bad happens).
Hope you are able to install your applications soon.
Regards, Carlos
Jun 09, 2010 | HTC Tilt 8900 Smartphone
I installed the npr ap on my storm. It quit working so I deleted the ap. The icon is still in the ap folder but blue now. Clicking returns 'module handle 3799 not found' - the Blackberry key does nothing...
Hi, Please go to service book options, and check if any service book for that particular application is available. If it is available then please delete the service book of that particular application. The icon will get deleted from the application folder. I hope this information will help you.
Nov 21, 2009 | RIM BlackBerry Storm 9530 Smartphone
My HTC P4350 is running low on free storage space
The system have used nearly the maximum internal memory available: Storage: Total 33.45 MB; In Use: 32.80 MB; Free: 0.66 MB Program.
If you already deleted or moved to memory card your files, that means that the space is taken by installed application/games, or by files left over by previously installed applications.
Save all your files on computer and do a complete reset of the HTC, restoring system to factory settings.
Aug 28, 2009 | HTC P4350 Smartphone
(french)i have bberry curve 8330 and i receive a eror code 205..
If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
Jun 09, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
HTC EVO 4G Smartphone Logo
47 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
