Question about Dishwashers
Hi Heatman, I have a whirlpool integrated Program 2000 machine APDW/1 which began giving trouble recently with the beeping noise staying going and not been able to move on the wash cycle but by stripping off the control panel and unplugging items etc, i got it working ok but now a week later it has suddenly died , power still going into it but no lights on the start, and program cycles etc so it sounds like a panel problem or could it be something else - any ideas Thanks Martin
  • Dishwashers Master
  • 43,501 Answers
Hi Martin,
I would agree with your assessment, if all of the wires are still attached okay....of course I'm sure you already checked that...
so... the logical thing would be the control next...
heatman101
Posted on Mar 23, 2011
When I hold start button, longer beeping noise won't start
might be your lid lock are door lock switch is bad if you have your manual tell how to put washer in program mode then it should give you a errcode show you what wrong with your washer ok
Oct 21, 2017 | Whirlpool duet Washing Machines
I have problemwith my PROform 585 treadmill and recently it is stop working ,as soon as I put the machine on it makes 3 bbeps noise and its stays like that for ever ,could not get it start it at all a
1) lUBE THE deck belt vs deck, this produce shut down for to protect the treadmill in your electronic system
2) lUBE The rollers bearing very well.
3) Measure the input voltage motor , if there are voltage, the motor need repair.
4)Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagram attached.
Jun 14, 2012 | Proform 585 CS Treadmill
Washing machine making loud banging cracking noise.
Sounds like something's got between the drum and tub and is resting on the heater element. Remove the heater and check in the gap
May 09, 2012 | Washing Machines
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LSN8244AW0 began making a loud thumping noise which quickly got worse then turned machine off; appears that tub is off balance and hitting all four of the inside walls during spin cycle. Do i...
The problem might be springs of the unit might be loosen or the suspension which holds the washing machine drum unit kindly replace the after checking which is faulty.It is difficult to find in spring but in suspension it must not go freely if if goes freely means kindly replace the suspension this problem will be solved
May 15, 2010 | Washing Machines
Beeping noise after installed memory on ecs motherboard L4S5MG
Some older computers, like mine, have a maximum memory they can handle. This one happens to be 1 gig, but yours may be less. Do you have an older computer? Yup, you do. As seen here, the maximum supported ram is 256. I'm sorry. Please rate.
http://www.dealtime.com/xPF-E-Machines-eMonster-500a-EMONSTER500A
Jun 18, 2009 | E-Machines eMonster 550 PC Desktop
Slow spinning agitator with knocking sound
agitator dogs. take them out and replace.
Feb 28, 2009 | Whirlpool Washing Machines
Whirlpool Range burners don't stay on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545111
Generic problem for all Kitchen Ranges
Posted by swetepi on Apr 25, 2008
I have a freestanding electric range that I purchased 1.5 years ago from Best Buy and rarely used. This is a sudden problem that began yesterday. All the burners come on , but stay on only 1 second, then go off for a minute then come on again for a second. Whirlpool will not give any technical support at all.
I can' afford to have a repair man out. I do not know how to get at the control panel. Can you help? I will never recommend Whirlpool.
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
You may check your factory owner’s manual under the trouble shooting guide to see what is happening. Do you have a glass top or the top with metal burners?
If you have the kind with the metal burners the top in most cases are on a hinge and will lift up for service, you definitely have a short somewhere or a loose connection, check with Whirlpool’s customer service to see if they can send out a owner’s manual from the factory or check to see if it is still under a factory warranty and if it is there would be no charge. Or check with your local Whirlpool appliance dealer – sometimes they can be of some help. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://whirlpool.com/home.jsp
Contact Us
Hours: M-F 8am–8pm Local Market Time
S 8:30am–5pm Local Market Time
- Get shopping help
- Order parts and accessories
Call 1-866-698-2538
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Apr 25, 2008 | Kitchen Ranges
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Hot surface indicator
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Dishwashers Logo
140 people viewed this question
Top Dishwashers Experts
