Question about Sylvania Televison & Video
My son hit his head on our sylvan ld320ss1 and now the tv blinks and quickly goes back to standby mode
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
  • 51 Answers
SOURCE: The tv turns off automatically & standby light blinks 4 times
4 blinks is bad backlight inverter. Download the service manual here:
http://rapidshare.com/files/208591107/KDL40S2000_L5_sm.pdf
Posted on Aug 22, 2009
SOURCE: 40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Posted on Oct 01, 2009
  • 1274 Answers
SOURCE: My Sony tv screen blinks off and on and timer/standby blinks 5
Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
Posted on Feb 26, 2010
  • 3 Answers
SOURCE: TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Posted on Mar 13, 2010
My son hit the tv and now it wont urn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 27, 2014 | Emerson LC320EM2 32" LCD HD Television
Slyvania flat screen tv will not turn on?
Mar 21, 2014 | Samsung LN-S3241D 32 in.LCD HDTV
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony Flat
Goes from on to Standby by its self because of protection mode that activates for some internal problem. Do you see standby light blinking on tv front? What is model number of your tv? How many times standby light blinking after 3 seconds long pause? Let me know to find out possible cause of problem.
Jul 25, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My son stepped on a remote control for a DVR. The Sony Trinitron Wega KD 32FS130 went blank. Now it won't come on, goes into standby mode, with the red light blinking four times. Any suggestions?
It is possible that the button your son stepped on is stuck. If so, remove the batteries form the DVR remote control and see if the TV works. Unplug the TV from the wall for a few minutes to clear its memory to be sure. Some times remote controllers can have cross-talk, meaning it can affect other equipment,
Dec 27, 2009 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Tv shuts off and goes into standby mode
When TV goes to standby,
count standby light blinks and let me know as it is error code to provide you info about problem in TV.
Aug 10, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Stuck in standby
Sorry about that. When the tv goes bad like not turning on, the green light will blink, and goes right back to red standby light while the dtv letters will briefly show on the lower right of the tv screen, then go back to blank screen. The tv will need to be taken to an authorized service center for repair. Common causes are a bad inverter/power supply, power control board, or circuit board.
May 16, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Standby mode and can't get tv to work
This sounds like the set is in protective shutdown. A problem has been detected and the set shut down. Normally when this happens, the standby light will blink a code count. Can you count the blinks and post that number here? That will indicate the circuit in which the problem was detected. Also, please confirm that the model number of the set is: KV-36HS500 as the blink codes are different based upon model.
Thanks,
Dan
Aug 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Televison & Video Logo
19 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
