Question about Bosch 4000 - 07 Electric Table Saws
My Bosch table saw motor runs but sparks are coming out the back of the motor. I replaced the bushings and that didn't help. Please advise.
  • 2,510 Answers
The sparks are most likely coming from the brushes and the commutator. This is an indication of either worn brushes or an armature that is failing and if used further, will burn out. First check the brushes and look at the condition of the commutator. These motors are known to be problematic.
Posted on Mar 23, 2011
D27105
you have armature problem,burned,shorted
Jun 13, 2012 | Dewalt DW745 10" Compact Job Site Table...
Bosch 4000
The speed control on your table saw works by sensing what's going on in the field. If you replaced the speed control circuit board and the motor still runs out of control, the next item to replace is the field.
Feb 10, 2012 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
10' table saw the litle fan inside the motor got broken en now it is making alot of sparks,what is the problem
sounds like the bushings have failed they transfer power from the power supply to the motor its an easy fix that wont be to expensive if you have some confidense in taking it apart you can buy the bushings and replace them your self if i`m sure a local handyman/store could do it for you and have a look at the fan at the same time
hope this helps
John
Feb 25, 2011 | Craftsman 10" Table Saw
Motor starts then stops i'm thinking bushings in motor
There could be two issues here there is whats called a soft start module in the motor that could be causing you problem, when the motor gets up to speed it shuts off, replacing the module will solve that proble. Or it could be the rear armature bearing has seized, usually they seize so tight they will stop the motor rotation.
Dec 28, 2010 | Bosch 4100 09 10" Worksite Table Saw...
I was cutting 2" dense foam insulation board,
The problem you have is a faulty field coil, the Bosch saws unfortunatly have a bit of an issue with this. The coil can be replaced separatly so you won't have to replace the whole motor. Bosch has a 1 yr warranty on thier table saw so this is a warranty replacment provided the saw was purchased within the year. If not the coil replacment is still cheaper than buying a whole new saw, but should really be done by a service center because of the level of difficulty of the repair.
Nov 10, 2010 | Bosch 4100 10" Worksite Table Saw
Bosch 4000 Table Saw running backward
You can find the 4000 manuals and parts diagram at bosch tools online. You will need a new armture Bnew bushes and possibly field. I would also replace the bearings and motor speed control circuit board.
Bosch does not sell the motor assembly.
Turn unit upside down and remove the Plastic body - approx 6 screws.
Thake a digital camera and take LOTS of pictures of dissassembly as you will need them later. Blow unit clean and work neatly keeping all parts in labeled bins for reassembly. Don't attempt this job when your pressed for time.
Before you start check to see if this machine is still under warranty!!
Call customer support listed on website if you run into a problem.
Good Luck !!
May 19, 2010 | Bosch 4000 Factory Reconditioned 10"...
Bosch table saw model 4000. Brushes where sparking alot .
It sounds like the armature is gone, if you are lucky the field coil is ok. Pull the back of the motor off and have a look at the armature where the brushes run if it looks burned or really rough the armature is gone and must be repalced.
Jan 08, 2010 | Bosch Saws
What size is the set screw (part #30) that holds thre bushing and prevents the motor from free-sliding up and down the threaded rod?
finally got it. the screw is M5x0.8x8 If I have helped you with your request would you please rate this response accordingly and thank you.
Oct 11, 2009 | Bosch 4000 - 07 Electric Table Saws
Bosch 4000 - 07 Electric Table Saws Logo
636 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
