Question about Lands Phones
Change the pre-set numbers - Lands Phones
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lands Phones Master
  • 102,366 Answers
Step 1: determine the make and model of your phone.
Step 2: repost your question, being sure to include the information from Step 1.
Posted on Oct 18, 2011
SPARK PLUG GAP
Since about 1985 or so, almost all spark plugs are factory pre-set for the application.
That means, if you buy spark plugs new for a 1988 Chevrolet Caprice Classic 350 V-8 engine, they will come in the box pre-set to about .035, which is the proper gap. ( I do not have these numbers memorized).
About the only time you would change the factory setting is if you were racing or something, and if so, you'd not be asking this question.
God bless your efforts.
Sep 04, 2015 | Cars & Trucks
Rinnai tankless water heater
the tempreature can be changed by changing dip stick numbers inside unit, If your unit is pre set @ 50 & installed before 2002 than you may have to change the mother board. If its preset 50 & after this date you can raise 3 - 4 degrees. If your unit is pre set 60 than you can go up & down. Manual is located inside cover, First check which unit you have, Before you do change anything take a picture first, so you can reverse what you have done if need to. ALWAYS TURN POWER TO UNIT OFF BEFORE REMOVING COVER.
Jan 11, 2014 | Rinnai Water Heaters
I would like to pre program a new fax #. add it
1. Press function 64 set to print out a directory.
2. Press function 72
Choose 1 touch
set
press the next available number with the small yellow numbers such as 02
enter fax number
set
enter name
set
Continue or press STOP
Mar 27, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I brought a set of security cameras that work on 2.4Ghz and this router F5D8236-4v1‏ is interfering with it. Is there a channel that does not operate on this frequency that I can change it to. Also,...
you can go into the routers settings and for wireless change the channel 6 is default and i believe that is 2.4 GHZ the smaller the number the less freq. the bigger the number the higher the freq. if you go higher. It is possible it may interfear with a cordless phone when you make the change so you may need to play with the setting
Mar 25, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Phil20124
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
Network Unlock on Optus
if you press *"06" and get me your imei number i can talk you through how to unlock your phone so it will take any network or any sim card but need your imei number first so i can get your unlock code as they are different for every phone hope to hear from you soon
Nov 14, 2007 | Nokia 1100
Changing Fax Numbers
press usertools/counter switch.select fax features by scrolling the arrow keys.press ok. In that you can see program/delete function.press ok you can see the options
Sep 27, 2007 | Ricoh Aficio 1018D Copier
How to delete a pre-programmed fax number
If all else has failed and you cannot change the settings or change the numbers in the program itself, often uninstalling and reinstalling the fax can correct the problem
Aug 15, 2007 | Gestetner DSm735sp Printer
Lands Phones Logo
18 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
