Question about Water Heaters
Pilot lite does not lit please advise what to do.the burner stays on if lit directly with open flame.is this dangerous.
    Novelist:
  • 144 Answers
What you describe is typically caused by a faulty thermocouple. The thermocouple senses the heat from the pilot light and TURNS OFF the pilot when it no longer senses the heat.
When the thermocouple turns off the pilot, it's not necessarily dangerous, but the water heater won't turn on without help.
Posted on Mar 23, 2011
Richmond gas hot water heater. After I light pilot and main burner why does it flame out in 15 seconds?
If you had to light the main burner manually, something is wrong. Once you light the pilot and it stays lit, the flame heats the thermocouple to open the gas valve and fire the main burner. Either or both of the components you replaced could be defective.
Sep 10, 2015 | Water Water Heaters
What pilot light assy. do I need to buy for model# 640y0rt4, water heater ??? please wont stay lit
check that the flame sensor is clean. It would be a stiff piece of wire that would sit right over where the pilot lite is. If it is dirty...it wont sense if there is a flame....and if it dosnt sense a flame....it wont let the pilot lite to turn on.
Jun 03, 2015 | Reliance 606 Series 40 Gallon Natural Gas...
How to light the Bosch TF250 pilot light
I believe this is a hydro-sparker pilot ignition then burner on when T-Couple/Flame Sensor acknowledges pilot lit.
W/O the signal feedback the Gas Valve will not open and light burner.
This is a Technician Service Job as you have insufficient knowledge to DIY this potentially dangerous LP/NG Control Valve/Sparker Assembly
I assume that lack of knowledge by your lack of a Manual for the Unit
You cannot force ignition on a hydro-sparker manually.
Sep 08, 2014 | Bosch Water Heaters
Richmond direct vent water heater
The pilot lights then heats/sends a signal to open gas for burner then(burner)should stay on but if valve shuts the gas off,then have your unit checked. What ever you do,DON'T MESS WITH IT IF GAS/FLAME ON!!!!!. These systems come with a safety feature that allows gas to go on only when safe!!!!
Mar 30, 2014 | Water Heaters
Gas burner wont stay lit
Is it the Pilot, or the main burner that won't stay lit?
The pilot has a little 'flame rod' in the path of the pilot flame, that conducts a tiny current thru the flame, to a detection circuit-- assuring that there is a pilot flame-- If that rod get's dirty, it can cause false trips. Is that any help?- Mack B
Oct 25, 2013 | Honeywell Pilot Burner for Natural Gas,...
Suburban hot water heater sw6p shooting out flames
Quit screwing around and shut gas off at tank valve and call a professional ASAP!!!!!!!!! This is a serious and quite dangerous situation. Fixya is full of people who think they know. This is a situation needing a hands on experienced professional,not a bunch of whining incompetent egocentric morons.
Dec 03, 2012 | RTO Suburban Rv Water Heater Dsi Gas Valve...
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
I have 2 rheem lp gas water heaters side by side and put a new pilot assembly in one but can not get either pilot light to stay lit do you have any ideas. thanks greg Thoms
hey greg. most likely its your flame sensors... right near the burner pan, there will be a 1/8th inch diameter metal rod, that should be positioned to be directly in the pilot flame when the pilot is lit. most likely if they havent totally burnt out, you should be able to clean them up with a piece of heavy grit sanding cloth. cheers
Jun 19, 2010 | Water Heaters
Pilot wont stay lit
Check the thermocouple,Its is a flame senser.It will not stay lit if it is bad.
Oct 04, 2009 | Water Heaters
Water Heaters Logo
101 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
