Question about Hoover Nextra HNL 3166 Z Front Load Washer
My Hoover HNL 842 wont drain/spin. Have removed/cleared filter, pump is working. pipes are clear. Now what?
  • 4,399 Answers
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Posted on May 02, 2011
My Hoover BOSS 2315l started having issues not finishing the spin cycle, now it just continues to turn off every few min, so I need to keep restarting it. Does anyone know whats wrong please.
Symptomatic of a blocked drain pipe, blocked filter, or a failed drain pump, drain pump with a broken impeller.
Remove the filter cover and check for obstructions. Attach a hose pipe to the drain hose, wrap it with a towel, hold the two hoses over a bucket and get someone to turn the hose on until you can't hold the pipes any longer, usually about 15 seconds. This clears obstructions in the pipe into the machine drum and filter. After checking the filter and behind it, put it on for a rinse and spin.
If the pump has failed, you can drain the machine by lowering the drain hose into a bucket or floor drain.
There are videos online on how to change out a faulty drain pump.
Jan 22, 2018 | Hoover Washing Machines
Hoover 1200
Remove all excess water by draining to a bowl. Clear filter and drain pump blade and all will be fine.
Jul 15, 2012 | Hoover Washing Machines
Hi,My daughters washing machine (Hoover Nextra HNL 842) fails to empty after washing cycle.(error code 3). I intend to check the pump and float switch.I can access the pump through the bottom of the...
You should have a drain filter. They do become clogged and need to be cleaned out. If the draine filter is clogged you will immediately know it upon removal and inspection. If this is the culprit, be sure to show your daughter how to access it, remove and clean it and then to reinstall it. This can be quite frequent (8 to 12 months) depending on her environment, like allot of pet hair and things like that. Let me know if this is the culprit. By the way, you are going to have to bail as much water out of the drum as posible unless your model has an easy water shut off just prior to the filter. Otherwise, all the water left in the drum will run out of the filter assembly when you remove it. With any luck the filter is the culprit and not the pump.
Nov 21, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Will wash but won't spin unless water syphoned off by draining through pipe into low bucket. So, the spin motor is ok, the pipe is not blocked... but the pump..... how can I get to clear out the pump?.......
Check to see if there is a filter located at the bottom front of washer behind plastic trim, if no filter, then remove rear panel of washer, and remove and check pump for blockage or malfunction.
Please rate my so9lution.
Thanks
Nov 01, 2009 | Washing Machines
NOT SPINNING OUT DRY ENOUGH
There is a partial blockage in the drain line. You need to remove the pump and check for obstruction at the impellers. If clear, check the pipes from the drain motor back to the drum and to the pipe outlet for partial blocking.
Oct 23, 2009 | Hoover HTC243 Top Load Washer
The pump on my hoover washer hnf7148 has been changed but the problem persists. Water is still in the drum and it will not drain away. The control panel when the machine stos shows the door closed with...
This particular model has a problem with the circuit board(control board,PCB) it does everything but drain, its very easy to replace and costs around £52
Jun 24, 2009 | Hoover Washing Machines
Water wont drain away but there is a time delay button flashing but it is not seleccting a time.how do i cancell this program so i can drain water from machine.the machine model is a hoover hnl 842
unplug for 40 minutes to reset the controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 31, 2009 | Washing Machines
Hoover hnl 6166 not spinning
have you tried cleaning the filter at the bottom. remove the front plateat the bottom and there is a small round plate at the left. this has a screw in it. when you have removed this you give it a twist. a bucketload of water and gunk will come out. i found about 60p in 5's but when it was all removed it started to work again
Jan 07, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover Nextra HNL 3166 Z Front Load Washer Logo
591 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
