Question about Garmin U232-P9 MCT GPS USB to Serial Adapter for GPS (U232P9) Serial Adapter
Target not connect or target is error status!
Upgrade log: ---------- HWK Update Client v
Authentication stage error: Error: Server returned unrecognized reply
ufs 3
Oct 06, 2013 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Default system password
Upgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:9/11/2013 2:41:46 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 72066
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-AFFA44634260001C
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Sep 07, 2013 | Panasonic (KX-TDA200)
Hwk authentication stage error no more upgrade logs
Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller.
Mar 22, 2013 | Cell Phones
Upgrade log: ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:6/11/2011 7:02:40 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft...
Upgrade log:
---------- HWK upgrade started:8/1/2013 6:34:25 PM ----------
-- UFSx S/N : 56512
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-DA0064A542600069
Jun 11, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Speed error 26
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
May 18, 2011 | Precor 923 LowImpact Treadmill
How to download hwk update client v 2.1.0
Upgrade log:
---------- HWK upgrade started:6/2/2011 6:35:55 AM ----------
-- UFSx S/N : 78650
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-DE6985914260006D
Oct 07, 2010 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Receiving target rate limit reached status detail code 5
how can i fix it it says Target rate limit reached. statusDetailCode 5
Oct 06, 2010 | AOL Instant Messenger
Serena Mover
Hi , you are not authorise to access the Target Server.Please Create valid Login and Password
Jul 30, 2008 | Serena Mover 2.0 Server (MOSERCSN20)
Garmin U232-P9 MCT GPS USB to Serial Adapter for GPS (U232P9) Serial Adapter Logo
677 people viewed this question
Top Garmin Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
JMEX
Are you a Garmin Computer and Internet Expert? Answer questions, earn points and help others
