Question about Creative Labs EP-630 Consumer Headphones
My EP-630 right earphone won't work. Playing with wire coming out of the 3.5 mm jack, seems to solve the problem temporarily. 1. If I repair it myself (re-soldering a new connector), will I be able to retain clarity of original gold plated 3.5 mm jack. Where can I get good quality 3.5 mm Jacks? 2. Will getting it repaired by a technician help to retain originality? Also where can i find a technician in Mumbai?
2 Suggested Answers
Grubhead
  • 5444 Answers
SOURCE: i was trying to see if there was a problem with
See my tip on dealing with faulty wires/plugs on headphones.
Posted on Oct 27, 2010
About my tasco 46-060675 D=60mm F=900mm come with 3 eye lense 1(sr4mm) 2 (k10MM) 3(k25MM) and two tube 1(1.5x erecting eyepiece) 2 (3xbarlow lense
The different eyepieces are to give different magnifications. This is worked out by dividing the focal length of the telescope, f = 900, by that of the EP. So the 25 mm Kellner (that is the type of optics in the EP) will give 900 / 25 = 36 times magnification.
The erecting eyepiece is used for terrestrial viewing. Normally with an astro telescope everything is upside down as that does not matter when looking at a star. So when you want to look through someone's bedroom window you use this.
A Barlow lens is an add-on magnifier. If you add this onto any EP (it normally fits between the EP and the scope) it will increase magnification x 3.
There is a practical limit to what any scope will deliver, governed by its aperture (the size of the front lens) and for your scope this will be about x 120 magnification. Beyond that the image becomes too dim and fuzzy. This means that your 4 mm eyepiece ( x 225 magnification) won't be much use. It will be hard to find the object you are trying to observe, it will be hard to focus, and the image will wobble around. Nor is your barlow lens much use either I fear.
You might consider another eyepiece around 18 mm to give a nice spread. A Plossl type is good. If you get serious about astronomy, I think you will immediately want a better scope after using the Tasco.
Mar 23, 2015 | Tasco Optics
Bought turtle beach z11 headset, cant get mic to work
The Z11 has a four-pole input/output plug to connect the mic and the earphone. The earphone needs to be connected to the earphone jack and the mic needs to be connected to the mic input jack on the back of the computer. In other words, you should have to 3.5 mm plugs. Plugging both into the same jack will disconnect one or the other. Check your adapter, It should have two separate 3.5mm plugs. If it does, be sure they are connected to the right jacks on the computer. The headphone jack will have a headphone symbol; the mic jack will have a microphone symbol. Go to System Preferences, Sound. Select the line in preference for input and the line out preference for headphones. Just may work.
Mar 14, 2014 | Apple iMac G5 Desktop
Earphone-only left earphone works... how can u repair right earphone
Rotating the jack or twisting the wire joint on the headset might work.
Nov 09, 2012 | Bose Around Ear Headphones Earphones
Earphone jack doesn't seem to work
tried to hooked up with other earphone jack first, if still doesn't work check the earphone jack of the tv which may have loose contact joint in the board.
Oct 14, 2012 | ViewSonic Televison & Video
No sound from ear phones of Fujitsu S-series laptop
First ensure that the headphones are working, by testing them on a divverent devices.
Ensure that computer has sound from speakers, if computer has not sound at all , then you need to reinstall audio drivers.
Then restart the computer with earphone plugged in, this solves a bios control related problem.
If still no luck, than you may have a broken solder joint on the Jack socket, in that case the repair must be done by a technician.
Jan 07, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Internal speakers not working
try reinstalling the audio drivers first
as it seems to be an issue with either drivers or with the sound card
provide more info like
when was it working fine
wots the operating system you are running
Jun 06, 2008 | Computers & Internet
Sound Only Comes Out Of The Right Earphone
If its less than 1 year old, have it replaced. Its a loose connection on the circuit board. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 24, 2007 | SanDisk Sansa e200 MP3 Player
Creative Labs EP-630 Consumer Headphones Logo
50 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
