I have a Stackmaster Paper Pro stapler (staples up to 100 sheets) and it appears the spring mechanism is broken. How do I fix?
5 Suggested Answers
  • 215 Answers
SOURCE: Paper tray not lifting the paper up for the initial paper feeder
most common problem on these is the rear paper stop pressing too hard against the rear of paper causing paper not to lift. make sure you have about an 1/8" gap.
good luck,
razors
Posted on Jan 09, 2009
SOURCE: Paper tray won't feed paper & I get a false paper Jam code
This might work for you - it worked for me. HP paper was feeding crooked. Checked the "Paper Type/Quality" in the printing options window - mine was set to Photo Paper. When I changed it to Plain Paper, the paper fed evenly. Hope this works for you.
Posted on Mar 11, 2009
  • 7 Answers
SOURCE: Lexmark E330. Progressive paper feed
I would consider two solutions:That there is something blocking the paper path now, and that the pickup rollers are dirty.
First, clean the pickup rollers, and anything that looks like it helps with feeding paper. Use some rubbing alcohol and a clean cloth. Getting it clean and 'grippy' (like rubber should be), should solve the pickup and feeding problem, unless there is blockage. The E330 isn't too hard to take apart, and searching online for a Parts Guide isn't too difficult.
Also, make sure that the paper guides in the tray are snug with the paper.
Posted on Jul 16, 2009
tommya300
  • 724 Answers
SOURCE: The stapler will not staple pages
sounds like it needs to be oiled
Posted on Aug 02, 2009
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
What is a stapler?
"A stapler is a mechanical device that joins sheets of paper or similar material by driving a thin metal staple through the sheets and folding the ends. Staplers are widely used in government, business, offices, homes and schools" (wikipedia)
Oct 06, 2013 | Office Equipment & Supplies
RAPID DUAX CUTTER MECHANISM IS BENT
Easy to dismantel more diffucult to built it back. Thanks to pictures, you can manage to build it back.
This pictures are useful because when you will dismantel the duax, the springs will spring without you had noticed the position of parts.
rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-2.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-4.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-7.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-11.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-16.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-22.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-29.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-37.jpg
Mar 25, 2013 | Rapid DUAX Heavy Duty Stapler 2-170 Sheet...
My PaperPro One finger 15 sheet power Stapler just stopped stapling. ???
The answer to this problem is simple. When you pull out the mechanism to reload the staples, there is a small metal black piece on top of the mechanism attached to a spring that drives the staples. When reloading, often times the driving piece gets flipped backward. All you have to do is flip this piece over and is should snap back into place. Fixed!
Dec 05, 2012 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
How to load staples?
  1. Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
  2. Load the heavy duty staples into tray.
  3. Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Resource 1 : eHow Article
Feb 21, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
Apsco A9 loads apsco HO staples, can remember how to put the staples in it anymore.
Carole - re A9 Apsco stapler - my A9 is not a staple-gun but is what I call a heavy-duty stapler for 10+ sheets of paper. There is a hinged metal hood at bottom end of handle (beige colour on mine). If you pull that metal hood upward towards you (being the handle mechanism) you will see the staple loading track mechanism with tradtional-lever that releases spring for loading staples. Good luck!
Feb 08, 2011 | Tools & Hardware - Others
The stapler will only work 1 time. then you must manually push the staples forward. the spring is not strong enough to do that. thanks. Jim
Usually, it is not the spring, but, rather, the stapler is clogged. Turn off the power and gain access to the stapler slide mechanism. Look carefully along the track and the hammer mechanism for pieces of a broken staple or paper chad. Wipe clean and give a light spray of silicone, wipe down and re-assemble. This should clear the problem. Please post back if other issues arise from your inspection.
Best regards, --W/D--
Jan 13, 2011 | Office Equipment & Supplies
Panosonic Electric Stapler does not staple paper!
It could be either jammed up with staples or the spring mechanism is shoddy.
Apr 14, 2009 | Office Equipment & Supplies
256 people viewed this question
k24674
jasbo
jasbo
