Question about RIM BlackBerry 8100 HS-655 Bluetooth Headset HDW-12747-001 Wireless Headset
Where can I buy an ear gel for my Blackberry bluetooth? The existing one has completely perished.
How do I get my wireless headphones to work with my iMac
If they are Bluetooth headphones make sure they have fresh, fully charged batteries, go to System Preferences and open the "Bluetooth" panel, click on the "+" sign near the bottom left of the page and follow directions to pair headphones to your computer.
Feb 02, 2013 | Apple iMac Computers & Internet
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Good luck to you..
Feb 01, 2011 | Cell Phones
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Tips & Warnings
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
Have a jawbone bluetooth ear piece trying to pair it with a blackberry cant remember how to pair it
I have two jawbone headsets and they won't pair with our blackberry phones. Can you help me
May 20, 2010 | Cell Phones
Missing 2-Ear Gels
We only provide tech user support, we do not intervene with a supplier.
Oct 22, 2009 | Jabra Bluetooth Headset with Adjustable...
Motorola stereo bluethooth headphones
The G1 Doesnt support Bluetooth A2DP yet, meaning it cant stream music via Bluetooth. Yet !
Oct 27, 2008 | HTC G1
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    Pairing headset with Blackberry Pearl
    On my blackberry I have to turn bluetooth on. Then on the WEP 200 hold down the button untill you hear a series of beeps. The light should blink every so often once its on. Then go to bluetooth options and search for devices.
    Jun 07, 2008 | Samsung WEP200 Headset
    Music problem
    i dont know how to download music on the motorola s9
    can u help me please
    Jun 02, 2008 | Motorola Mobility S9 Headphones
    RIM BlackBerry 8100 HS-655 Bluetooth Headset HDW-12747-001 Wireless Headset Logo
    Top RIM Radio Communications Experts
    eradiostore
    eradiostore
    Marvin
    Marvin
    Are you a RIM Radio Communication Expert? Answer questions, earn points and help others
