Question about Maytag Washing Machines
My top loading Maytag washer is knocking when it spins dry. Could this be a drum or belt problem?
    Brigadier General:
  • 6,277 Answers
(try this 'balancing trick' first!)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 23, 2011
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Clothes are dripping wet after spin dry cycle
You may have a bad belt not spinning the drum fast enough or not enough tension on the belt due to worn motor springs.
Jan 02, 2010 | Maytag PAV2300 Top Load Washer
Maytag PAV2300AWW, REV. 17, will not spin. Motor
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps
Dec 01, 2009 | Maytag PAV2300 Top Load Washer
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
Maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Jun 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Loud spin noise from Maytag washer
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.
Jan 05, 2009 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
