Question about Bosch Axxis WTA 3500 Dryer
The Dryer does not get very hot anymore and it takes a long time to dry clothes. I have cleaned out the vents and lent trap and the lent trap sensor. I think it could either be the heater or thermostat. How can I fix this? Are these easy fixes?
  • mikeging88 Mar 23, 2011
    I have thoroughly cleaned the ducts and lint filter. I have not replaced the lint filter it is 9 years old but I can see through it. I do not have a multimeter. How much do they cost? I assume that when your using the multimeter the dryer is disconnected from electrical power? We had a repairman out about a year ago and he claimed it was the heating element. His cost to repair it was a little less than a new dryer. After he left the dryer actually worked better than previously without any work on it at all, so I did not get it repaired. Does this alter your opinion or should I still start with the multimeter?
  • Bosch Master
  • 19,396 Answers
Hi.
To start double check the air ducts. If there is a lint filter, clean it and eventually replace it. A dirty lint filter may cause overheating and the thermostat will blow.
If there is no heating at all, check first the thermal switch (this is a cutoff with a red button located at the back of the unit in Bosch). First try pressing the button. Then test it using a multimeter set on Ohms. If the switch is defective it will remain open. The switch reading Ohms' infinity when you touch the switch contacts with the probes (after removing switch from appliance), then the switch is gone.
If the fuse is OK, then you can have a defective thermostat or heating element. This parts are located in the heating assembly. Before going for the thermostat, ensure that the fan is running, or that will be the problem (quite uncommon).
You test the thermostats similarly to thermal fuse.Set the multimeter on Ohms and read impedance. You need to disconnect the part's contact to test properly.If the thermostat is good it will read zero Ohms (or very low impedance) at room. If they are bad they read open (infinity).
The heating element is tested in the same way. Set multimeter on impedance, disconnect element, and touch contacts with multimeter probes. If it reads open, then element is gone. A good element reading depends on the specific model. Most dryers, including Whirlpool and Maytag read between 10 and 20 Ohms, the Axxis element impedance is probably higher than that.
Regards.
Ginko.
Posted on Mar 23, 2011
  • Ginko
    Ginko Mar 23, 2011
    Hi Mike.
    The multimeter is not expensive. A cheap tool will start at about $10. Use Google Shopping (option on top of Google page) to get choice in your area.
    To test parts, not only the power must be disconnected, but the part must be removed from the appliance (at least one of the two contacts must be cut, or connector disconnected. Although the repair job is not difficult, I have to remind that for safety reasons the repairs must be done by a trained person.
    Parts can be purchased from Bosch or from a local part seller.
    Regards.
    Ginko
Why is clothes dryer heating, but not drying?
Be sure to check the lint trap in the front and also the lint vent in the back. That is the big hose in the back of your dryer. Take it off and then ensure a bunch of lint isnt stuck. Empty in trash cans. Also you can get a lent vent cleaner which is a long pole to clean vents on the roof and also in the hose and pipes. This is important to clean at least quarterly to avoid any possible fires.
Aug 28, 2014 | Dryers
My dryer is heating fine but there is no air blowing out of the vent. Therefore, clothes are not drying properly. I have cleaned the lent filter, checked the outside and and inside vent for clogs or...
run the dryer with the vent hose off, if it drys correctly then it is in the vent tube. The best way to clean the vent hose is with a leaf blower, now if it is not drying with the vent hose off then you will need to disassemble the dryer, and clean from the bottom of the lint trap back to the back of the dryer with a brush(paint) and a vacuum:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My maytag 3000 series dryer is not even a year old untill 2 more days, it does not dry my clothes no matter what setting I have it on the lent trap gets cleaned about 2 or 3 times during each cycle,yet it...
oooow,,,temper temper,,,,take a deep breath,,,
i think the temp censor has stoped working thats why its not getting very hot its that or the heating coil/s are broken,,also check the air vents at the back are not blocked up if so its not getting any air to it,,,
then go out and find a big stick,,,and batter it with the stick,,,
this realy wont help fix it,,but it will make you feel soooo much better?
Jul 12, 2010 | Maytag Dryers
My electric dryer heats up but doesnt dry the clothes
If your vent hose is more than about ten feet long, your dryer may not have enough pressure to keep the air moving sufficiently to dry the clothes. Is it possible you are simply over loading your dryer?
Jan 25, 2010 | Kenmore 63942 Dryer
Dryer shuts down after 5mins and also has a random
I think the vent is pluged up or bent so that the lent is trapped in the hose. its getting too hot. don't use it anymore till you get it cleaned and check for lent build up in side. can cause fire.
Jan 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Dryer working but takes quite a long time to dry clothes
Hi either the vents are clogged with lint and you will have to get those brushes to clean the lent traps. or it is the element. Probably the former and not the latter. But it depends on the age of the dryer.
Jul 18, 2009 | Hoover HDC7FM Dryer
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Apr 22, 2009 | Kenmore 64672 Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Dryers Logo
99 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
