Question about Karcher K2.26 Electric Power Washer
Why wil the nozzle no longer stay in the handle ?it will not twist and lock
    Sergeant:
  • 259 Answers
Probably the plastic handle is worn where the nozle fits and there is nothing to keep it locked.
Posted on Mar 23, 2011
How to replace pull cord on Honda 13 hp?
with recoil starter removed and in hand you have to grab the housing with one and the other rewinding the reel by twisting it counter clockwise until you can't any longer every time you twist hold with other hand to prevent the reel from spinning back once your at the end align the holes and place a small screwdriver and insert it through for it to stay together without unwinding.next is to tie a knot on one end of rope feed through handle then through the aligned holes and tie other knot then you carefully remove screwdriver and your rope will reel in:)
Aug 18, 2014 | Honda Garden
Why wont my MVP super lift f-765jsw 2 ton stay up?
If it won't stay lifted when you twist the handle as tight as you can, then the lock valve may be leaking, Barbara. Examine the hydraulic cylinder - you may be able to spot a crack or something.
For now, though, just twist the handle clockwise as hard as you can. That valve is steel - it's VERY difficult to damage.
Aug 12, 2014 | Cars & Trucks
My door won't close at all bounces back a bad lock on a ford ka? i wil buy another lock but do i need to get the key of the new lock or i an stay with the one i have?
door lock latch is closed you need to release the locking mechanism at the side of door with screwdriver while holding door handle open to release the latch then door lock will operate as normal
Jan 20, 2014 | Ford Ka Cars & Trucks
I can't get the screws out to replace the belt on my carpt shampooer...
No screws need to be taken out on a Kirby for a belt change. Take the nozzle off, remove the base plate with the 2 twist locks, pull the brushroll out. Puton the new belt, and re-assemble. Twist the belt lifter around the belt, replace the nozzle, spin the belt lifter back, and go vacuum
Oct 11, 2013 | Kirby Heritage II Vacuum
The stroller wants to turn to the right, it wont stay straight.
Turn stroller upside down (sans baby ;-) First spin each back wheel to check it turns freely and it's fully engaged into the chassis. Front wheels should spin easy and rotate 360. If this is all good check the handle locks, are both sides locked or is only one side locking causing the handle to twist and put uneven pressure on the chassis.
Nov 01, 2010 | Bugaboo Cameleon Stroller
Can you tell me how to pour water and chemical into the tank? the small nozzle for the gun is too small
The handle that you use to pump that sprayer will twist and come out... then you pour the water and chemical through that larger hole...replace the pump...twist it tight and then pump the pressure...
heatman101
Oct 27, 2010 | Rl Flowmaster FLOMASTER 1 GAL SPRAYER ()
I have a second hand Bebecar adventure raider stroller and cannot restore it from its folded position
To unfold the Raider, first press the red button in the middle of the handle and then twist the twist-grip in the direction of the arrow. Once you've done this, keep it twisted while you place your foot on the horizontal footplate. Once the chassis starts to open, pull sharply on the handles until both the primary and scondary locks engage. Make sure that the red latch is not visible, and check the security of the primary and secondary locks by gently pulling on the handle and pushing on the left and right mouldings.
Find out more by requesting a user-guide from service@bebecar.co.uk
Jun 21, 2010 | Bebecar Raider AT Stroller
Door wil close but not lock - no 'click' - flashing door light stays on
You probably need to fit a new door handle spring, as it is more than likely broken.
This is quite a common problem.
Dec 29, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
I can't change the belt on my Ultimate G Diamond Edition
You have to take the nozzle off. Then twist the handle to OFF position to catch and stretch the belt, put the nozzle back and then twist the knob to ON.
Instructions with pictures HERE
There is video manual on the front page on goodvac.com too...
Good Luck,
Rocky
Mar 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Change filter kurv dirtdevil
remove unit off base. twist handle from suction nozzle, it will separate.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 25, 2009 | Dirt Devil KURV Hand Vacuum Champagne...
Karcher K2.26 Electric Power Washer Logo
44 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
