Question about Brother IntelliFax-2820 Laser Fax
It says drum error but the cart and drum is replaced with new and still can't get past the drum error message.
    Novelist:
  • 129 Answers
Hi There!
What you can do to clear the Drum Error message is to clean the corona wire.
  • Open front cover of the machine and remove the drum & toner cartridge assembly.
  • Remove the toner from the drum and gently shake the toner cartridge from side to side put it on a piece of paper to avoid scattering the toner.
  • Theres a blue tab on the upper left side of the drum, slide it from left to right, right to left about 5-6 times don't forget to put the blue tab back to it's home position(where the arrow is).
  • Put the toner back into the drum make sure it will click into place.
  • Reinstall the drum and toner assembly back into the machine and close the front cover.
  • LCD should display the date & time.
If you continue to receive the message try resetting the drum counter by doing the following:
  • Open the front cover
  • Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
  • Press 1 to reset the drum count.
  • Close the front cover
Hope this helps!
Vikroks
Posted on Mar 28, 2011
  • steve clarke Feb 06, 2013
    Hi, thanks for the tip. This worked on my RICOH sp1200 as l couldnt find it in the manual, but messing around with the menu etc found the replace drum Y/N line and selecetd yes and it worked. .
CHANGE NEW DRUM MESSAGE EVEN WHEN REPLACED IT
Is the drum 3rd party? if so it may not work, Mite have a bad Drum cart is it out of the box new. Take some alcohol and clean all the metal contact on the drum unit not the drum. Then reseat it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 23, 2014 | Minolta MF1600E Plain Paper Laser Fax
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Same problem even with new Brother drum
Did you replace the drum or the toner cart? The drum has a blue lever that you slide back and forth around 20 times to clean the corona wire. I sometimes use a cotton swab with alcohol to gently clean this wire as well.
Jun 23, 2009 | Brother MFC 8500 All-In-One Laser Printer
Showing system error code E019
Waste toner bottle is full. Needs to be replaced or emptied. I believe it is the drum cart. that will need replacing to correct the error. It is an all in one unit. Unless you are a tech and can take it apart it will need to be replaced, if it is under maintanence it should be covered.
Hope that helps,
TankMurdock
Apr 24, 2009 | Canon imageRUNNER 2000 Copier
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
New cartridge
Clean the copper contacts of the cart and reset back in the printer and if your getting the same error message please replace the cart with another cart .......
May 13, 2008 | Dell 922 All-In-One InkJet Printer
Printing and copying almost blank pages
Ussally drum/toner would fix, will not be fuser, I would suspect Hi voltage board or laser unit, In australia these machines carry a 2 year return to base warranty.
Try reseting the drum counter, this also resets Bias voltage, might be your problem. open front cover with power on and press set, arrow to change drom and select yes.
Otherwise it would be a high voltage board problem, possibility alsoexist that it could be laser unit
Check status page for "71" errors, menu * 2 8 6 4 very very fast, machine will beep "maintence displays" then 77 to print out status page, 99 to return to normal.
Nov 26, 2007 | Brother MFC-8440 All-In-One Laser Printer
Mfc-7220 replaced starter cartridge, new Brother one gives error no cartridge
there is a new toner detect sensor left front upper inside of printer, when a new toner is put in reset lever on cart hits sensor then fall back to front of cart, remove gear asst and put lever in new position, 3/4 the way back. reinsert toner into drum and insert.
Nov 03, 2007 | Brother MFC-7220 All-In-One Laser Printer
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Brother IntelliFax-2820 Laser Fax Logo
426 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
