Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Can't get the Power Save Mode to turn off - HP Officejet 6500 Wireless All-in-One InkJet Printer
    Guru:
  • 89 Answers
Try looking on the front panel of the printer
press set up button look for Tools or Preferrences then look for power saving mode then turn it off
If the front panel cant have it,connect it directly on a wall outlet not power strip
or more advance
press * and # at the same time then press 1234 consecutively then underware menu should appear on screen
if it does not show you that just keep on doing it until it appears
then use arrow keys and look for sleep mode/power saving mode then set it to 0 or off
Hope I help you a bit.
Your's Truly,
Christian from HP
Posted on Mar 27, 2011
Squelch won't turn off, won't go into power save mode
Power-save mode means the radio is being turned on and off repeatedly, to save power. The radio turns on, & if it hears any signals (i.e., if squelch circuit determines a station is being received), it turns on the speaker; else it turns off again to save power. So, squelch and power-save modes work hand-in-hand, and your problem is squelch circuit is either set too low, or a station is being received by the receiver. Download/look at the owner's manual and adjust the squelch circuit for a higher setting, and it should go into power-save mode again.
Good luck.
Nov 10, 2013 | Cobra LI 7020 WX-EVP Two Way Radio
How do i turn off power save mode using the screen buttons
I don't know if there is a monitor with a function button to turn off the power save mode.
As far as I know the power save mode of the monitor can be found in the display setting of the windows..
Anyway... If you want to turn off the power save mode of the monitor via windows display setting then here is what you need to do:
On control panel, double click display settings.. click the screen saver tab... on the lower portion Press the "power" button.. Select power schemes tab.. Change the settings of" turn the monitor off" to "never"
Click apply and then OK..
Hope it gave you an idea..
Much appreciated if you rate this help...thanks..
Uncheck the box
May 19, 2010 | Dell E173FP 17" LCD Monitor
Can not turn on power save mode
san_pesca, Could be unit is not in power-save-mode, but has CCFL blacklight failure!! But that's only a guess! NO previous history was given or approximate total "ON" hrs. of use unit has seen during it's life!
12fixlouie
Nov 25, 2009 | LG Flatron L1710S 17" LCD Monitor
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Power save mode
Your power saving mode is turned on.
try to turn it off, on control panel.
THANK YOU for contacting fixya.com
Oct 18, 2009 | Gateway GT5220 PC Desktop
No display machine goes into Power Save Mode
Not much to go on here.
I assume you mean the machine goes into power save mode and you can't get it back out again?
There are power mode setting in control panel.
You might need to turn it off so the power save feature is not activated.
There are also power save setting in the BIOS settings.
Again you may need to disable it or try different settings.
Sep 20, 2009 | AcerPower 2000-UD431C - Core 2 Duo E4300...
Power save mode
reboot your comp........enter setup at the laod screen go into power options and turn power save off.......save and exit
Apr 14, 2009 | Computers & Internet
Pc entering power save mode
I am having the same problem . The system is starting up and th epc entering power save mode. I have a Hp pavilion f1503 model monitor. I hit the power off button on the power surge to shut the entire power off. I turn the power surge button back on. Sometimes it works. Or have to hit the power on button to reboot.
Dec 12, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
Monitor keeps going to power save mode
the settings should be the same as your notebook power saver settings or you will have to check extended monitor in your graphics card properties in control panel.
Sep 26, 2007 | Toshiba (K000006610) for Satellite P25...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
752 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
