Question about Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
V4 lead not working - Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
    Problem Solver:
  • 17 Answers
The Schiller AT2 is usually very reliable in terms of the pre-amplifier, which is the section of the electronics that firsts processes the incoming patient signal. Your problem most likely lies in one of three places. Most likely is your patient cable. The best way to tell honestly is substitution. Try another known good cable. The second most likely source of complaint is your Gel electrode adapters. Open each adapter and inspect the jaws, you should see only shiny metal, no gunk, paper or corrosion. You can clean minor contamination with an alcohol soaked que tip( take care not to splash alcohol into your eyes, I've done it before doing this cleaning operation. Wear safety glasses. If the corrosion cannot be removed via cleaning, then a new adapter set is called for. As your problem is specific to a certain lead, you can try swapping the adapter from V4 to a known good lead, and see if the symptom moves to the other lead, if so a new adapter set should take care of your issue, good ones run around 40-50 dollars.If neither the cable or the adapters fix your problem, I have on infrequent occasions found defective input connectors, usually the solder connections to the main PC board. If this is the case, I would recommend sending the unit to a qualified repair shop. If work is attempted on a Schiller PC board, Schiller will no longer exchange it, and you only recourse would be to replace the board, at a price in excess of 2000.00. Otherwise, it can be exchanged for far less. We repair these boards, but they are multilayer and surface mount, and this type of soldering is not for novices.
Posted on Dec 05, 2011
How can i determine if i have a 1993 evinrude 120h V4 standars or ocean pro, what is the difference
you can check with a dealer . they should know by the serial number or model number .I worked for a dealer for 15 years and never heard of one but we are a land locked state no oceans here for 700 miles or more
Aug 01, 2015 | Boating
Tip
Motorola Phone Tools V4 Manual Download Have you misplaced your Motorola Phone...
Have you misplaced your Motorola Phone Tools V4 Owners Manual?
Would you like a digital, searchable, pdf version of the Motorola Phone Tools V4 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
_____________________________________
Motorola Phone Tools Trial V4 Download
Motorola Phone Tools V5 Manual Download
on Apr 23, 2010 | Cell Phones
Where is the thermostat on 1998 Toyota Camry V4?
the easiest way to always find your thermostat is by following the radiator hoses! it will always lead you to the thermostat housing!
May 24, 2012 | 1998 Toyota Camry
My Belkin Router model Number is F5D7234-4 V4 and I want to know if it is a compatible access point for a DSI. I found the list on Nintendo's website, and they have this model number listed without the...
If it is not working for your DSI, try going to your routers website and downloading a firmware update that would update it to version 4 (v4) and then your DSI should work!
Jul 11, 2011 | Belkin My Essential (ME1004-R) Wireless...
My car is honda accord coupe 1999 V4, EX. The problem is: the Mechanic could hardly start the car, and when it starts the RPM (round per minute) is very high, it's 2200 RPM.. is it caused by the ECU?
The EAVC and Idle Control Valve might be sticking. Remove air filter and pipe work, and inside the throttle body are these valves. Clean the up and reset the ECU - usually removing the negative battery lead will reset Honda's.
The ECU won't be broken or anything by the way, if that's what the mechanic was getting at.
(By the way it's Revs Per Minute RPM :)
Jun 22, 2010 | 1999 Honda Accord
V4 embroidery manual
Looks like you can download it directly from Bernia USA's web site. Go here and scroll about 3/4 down. There's a section for "Embrodery Software V4" with a link to "ADX V5.02 for BERNINA embroidery software V4". If you don't have a username and password you can create one.
http://www.berninausa.com/news-n32-sUS.html
Sep 09, 2009 | Computers & Internet
I cant find the serial key for nero 9 trial
Nero v9 : 9M03-01A1-PCX7-K31A-8A94-98PT-KT2E-522A Blu-ray Disc Authoring -in: 9M13-0083-2710-5622-98W3-TL0A-THW4-9A0T Gracenote Plug-in : 9M0C-01A2-K817-3LK8-9X6M-WK3U-L942-3WE1 DTS Plug-in : 9K00-0003-8M80-6320-5043-1458-XAA5 mp3PRO plug-in : 1A41-0800-0000-2903-1645-8530 Nero BackItUp v4 : 9M11-01CA-032E-01A5-AA9C-H44K-6T9U-X4HW Nero MediaHome v4 : 9M06-019C-TTET-880Z-5PUM-6XA2-5MEC-35WM Nero Move it : 9M09-01AC-5TE3-KEU9-177W-C6E0-6KCT-2W4K OR Nero v9 : 9M03-01A1-PCX7-K31A-8A94-98PT-KT2E-522A Blu-ray Disc Authoring Plug-in: 9M13-0083-2710-5622-98W3-TL0A-THW4-9A0T Gracenote Plug-in : 9M0C-01A2-K817-3LK8-9X6M-WK3U-L942-3WE1 DTS Plug-in : 9K00-0003-8M80-6320-5043-1458-XAA5 mp3PRO plug-in : 1A41-0800-0000-2903-1645-8530 or KC00-20K3-997A-2A6M-1MK2-889X-K9C7 Nero BackItUp v4 : 9M11-01CA-032E-01A5-AA9C-H44K-6T9U-X4HW Nero MediaHome v4 : 9M06-019C-TTET-880Z-5PUM-6XA2-5MEC-35WM Nero Move it : 9M09-01AC-5TE3-KEU9-177W-C6E0-6KCT-2W4K
Aug 16, 2009 | Ahead Software Nero 9 Full Version for PC
I have a new tom tom one v4 which is frozen in op mode?
Try the little reset button on the bottom. It is beside the sd slot on my TT One.
Jan 10, 2009 | Tomtom One Europe v2 GPS Receiver
Printer compatibility
Is your printer doing the same thing when you perform the self test of this printer (usually power held down for 8seconds or press power on and print at the same time) will identify either a print cartridge problem or a driver install problem.
Apr 17, 2007 | Panasonic KX B09-V4 (KX-B09-V4) Network...
Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine Logo
125 people viewed this question
Top Schiller Medical Experts
Jim Goldsmith
Jim Goldsmith
Andrew Taylor
Andrew Taylor
Are you a Schiller Medical Expert? Answer questions, earn points and help others
