Question about Sanyo DP50747 50 in. Plasma TV
I have a 2 inch line going down the middle of my screen from top to bottom. Would this be fixable?
    Sergeant:
    Champion:
  • 234 Answers
Yes it is repairable. You will need to have the video board replaced. That line usually indicates an error in the video board.
Posted on Mar 23, 2011
Black line through middle of emerson led tv screen
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs'.
Apr 23, 2014 | Emerson Televison & Video
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
40 inch Philips tv has a brown line in the middle of the screen, can it be fixed???
is this an lcd or plasma tv?. then does the line stay in one area or it was moving while the tv is working?. can you give this some detailed which can help out solve the problem.
Oct 16, 2012 | Televison & Video
There is a line down right side of projected image, from top to bottom, different computers. Thanks Loren
I have a 2 inch white line down the middle of the screen from my Infocus DPL projector.
Can you help?
Paul.
Nov 29, 2010 | Optoma EP771 DLP Projector
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes about half way down the screen.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Dec 06, 2009 | Zenith D52WLCD 52" Rear Projection...
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Sanyo DP50747 50 in. Plasma TV Logo
180 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
