Question about Panasonic TCP50C2 50 in. TV
Moved my viera 50 inch tcp50c2.from one place.and acidentaly forgot to take the antenna cable out and it broke.now the tv wont work.the back where the antenna goes its broken what can i do?
  • 158 Answers
You need to contact panasonic to check on your tv, it is possible that some components inside are broken as well which needs expert fix.
Posted on Mar 23, 2011
Testimonial: "thank you.but i think if i call panasonic i have to pay a lot of money"
    Sergeant:
    Champion:
  • 234 Answers
Have a service technician replace the broken part.
Why is cable reception snowy and exterior antenna said no signal?
Cable reception is a cable company question. The only reason I say that is because they will do it free for you. It is going to be signal too strong , too weak or it is a bad connector. The antenna is going to depend on a few things. Are you aimed correctly? If this and Omni directional then you need to figure out how far you are from the tower sending the signal. The Omni directional antennas are only good for 50 miles tops and that is some models. You may also need a preamp in line for your signal to be strong enough if you do not have one in line. If you have a lot of runs going on the antenna (several room feeds) then you may also need an adjustable amplifier after the preamp.
Feb 09, 2016 | Panasonic Viera TH-50PX80U Plasma TV
No picture when laptop is hooked to Panasonic TCP50C2 50 in TV
installing Bluetooth on an Acer laptop can really broaden the capabilities, making it easier for you to get your laptop online and network with other [url=http://www.sencart.com/Supply-adapter-and-charger_c426]universal power adapter[/url] ...
Aug 02, 2012 | Panasonic TCP50C2 50 in. TV
My panasonic viera has just stopped working. I can play a dvd but not watch tv, It says no signal. I have checked all leads and none are loose. It worked yesterday!! What is wrong with it? Please help
What is your TV source? Is it OTA, cable or satellite? Do you use a set top box or a direct coax cable connection? If you have OTA, what antenna do you use?
Try the following depending on your setup:
For all, check if a lightning/surge protector has taken a surge and needs to be replaced. These are placed in the coaxial line to divert a surge that could destroy your electronics. Also try replacing the cables. Check exposed cable for damage.
For OTA, first check that your antenna is oriented to point to the transmitters in your area. (Outside antennas will sometimes turn in the wind; indoor ones can be bumped.) Try a new coaxial cable. If the antenna has an amplifier (or you use a splitter with or without an amplifier), try connecting the cable directly without the device. I've had several amplifiers fail and turn into signal filters (blocking all of the signal).
For any system with a set top box, make sure that the box is on. For satellite, make sure that your dish hasn't moved out of alignment.
To check if it is the Viera TV tuner or the incoming signal, try another TV at the same connection. If you have cable and another TV gets no signal directly connected to your incoming connection, you may need the company to fix the incoming cable. (Underground cables can be damaged by rodents or neighbors who dig without checking for utilities.)
I hope this helps.
Dec 21, 2011 | Televison & Video
I have a panasonic viera tC-P50C2 flat screen. I bought a vga to hdmi conversion box and still the screen stays blank. On the menu it is listedas computer on hdmi 1. another problem is that the tv...
are you hooking up to desktop or laptop? if laptop you have to setup for dual screens or, most of them have a key you can press to change video output, usually one of the "F" keys will have a small pic of a box, sometimes in blue.
Mar 31, 2011 | Panasonic TCP50C2 50 in. TV
Why is resolution 1024 X 768 instead of 1365 X 768 like other 50 inch plasmas, this is not a typo
1024 X 768 was known as "The Sony Standard" in PC format. 1365 X 768 is slightly wider screen size, that is all.
Dec 19, 2010 | Panasonic TCP50C2 50 in. TV
Where do you plug the antenna cable into a 50" pioneer Pop-505PG Plasma TV
on the back of the viera in the middle is all the jacks, at one end is a standard cable tv/antenna jack...just screw the cable into it, and then have your tv scan for channels.
'you should be good to go after that.
Dec 18, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Connecting sony surround sound system to tv
i had the same problem what i did was conect a optical cable from the tv to my surround sound and hit the viera link button then i was able to change from tv speakers to home theater which automatically turned on my surround system and set it on the right mode to work cool feature now i dont even need all my contro i can turn on my ps3 and surround system with my tv control
Jul 11, 2010 | Panasonic TCP50C2 50 in. TV
Hdmi on tv loses signal
Try another HDMI input on your set and see what happens.
Jul 26, 2017 | Panasonic Viera TH-50PZ80U Plasma TV
How to connect nintendo 64 to panasonic viera tv
it depends what connector cable you have if you have an AV cable hook it into the red white and yellow colored inputs if you have an RS cable for the 64 screw this into the back of the tv where the antenna input is.
Oct 27, 2009 | Panasonic CT-27E13 27" TV
Panasonic TCP50C2 50 in. TV Logo
197 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
