Question about GE WBSR3140DW Top Load Washer
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the hose, water pressure is good. then we try to start the washing machine, while the water is filling up the machine, the washing machine also is keep draining.
    Sergeant:
    Champion:
  • 218 Answers
Make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Posted on Mar 23, 2011
GE profile wpre6150k2wt washer never fills up, water runs in and immediately drains and the cycle never stops. Status timer on front just has spinning lights
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
Jun 13, 2015 | GE Washing Machines
Pump won't drain water and keeps faulting for pump cleaning. Have turned it off, unplugged pump filter, cleaned it and restarted it several times with no luck. What else could be wrong??
Check to see if there is a drain filter. My GE has a small "door" at the bottom of the machine that has a filter behind it. If so ALL of the water will drain when you open it so be prepared. Then clean all of the junk from inside the filter or "trap"
If you need further help, I’m available over the phone at https://www.6ya.com/expert/justin_3ae27a9d61d6acd4
Apr 15, 2013 | Washing Machines
New washer draining out while washing or rinshing
If this is a brand new unit, make sure that the drain hose is hooked up at a level at or above the level of the tub. If it is too low, it can siphon the tub of water.
Apr 30, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge washer wbse3120b2ww does not fill water and go to the final sp
hELLO THERE
well it is looking like you have a water controle solinoid valve that is malfunctioning and needs to be replaces i would contact your nearest dealer to see what the part is going to cost and have it replaced and if you have a warranty with the machine see if you can use it .
best of luckmike
Jul 31, 2009 | GE Washing Machines
Washer machine not draining water
The GE serviceman repaired my machine approximately 40 minutes. I paid $189 for the issue to be resolved in 5 minutes. This is no exaggeration.
The serviceman arrived at 2:50pm and finished at 2:55pm. It took another 5 minutes for me to write the check and he was gone.
My recommendation is...
- Purchase the GE service plan prior to calling GE to repair the service. A 1-Year service plan is $40 and 2-Year is $75. It costs $99 just for the serviceman to come to your house.
- Fix the issue yourself. Of course, this only applies if you are handy. I am handy and I tried to fix the problem myself. I just couldn't figure out the location of the access panel.
Solution...
The access panel is on the front. This can be removed in less than 20 seconds. The notches on the access panel is in line with the edging of the washing machine door. To remove, slide in a flat object like a flat-head screwdriver. Wiggle up and down on each side until door comes loose. Lift up door and set aside.
The water pump is on the lower right in the front of the washing machine. If your wash machine has any water in it, you want to use a shop vac to empty it out. The serviceman used a clamp to stop the water from running down. A little water still came out but he used my shop vac to get it up. It was less than a cup full and I had a 1/2 tub of water. Afterwards, he stuck his fingers in the water pump and pulled out the item that was blocking the pump.
Guess what was blocking the pump? The item was my two-month old daughter's sock. He recommends using a washing bag.
Remember this solution is for GE 315 model that is a top load washer. This will most likely work with similar models. I knew my water pump was still working because it hummed during the rinse and spin cycles.
Good luck and I hope this saves you $189 or any other fees.
Nov 21, 2008 | GE WBSR3140DW Top Load Washer
NEW WASHER WILL NOT SPIN OUT ALL WATER. DRAIN IS NOT KINKED AND IS AT 48 INCHES OFF FLOOR. MODEL IS WJRE5550H1WW WE HAVE IT ON EXTRA SPIN AND WE MATCH LOAD; MED SIZE LOAD / MED ON COTTON SETTING
I have the same problem, I called GE and they said there is definitely something wrong with the machine if I can just wring a bunch of water from the clothes and suggested to put a service call, seeing as I bought it last week I am going to see if I can get lowes to replace it with a WJRE5500GWW instead.
Jun 02, 2008 | Washing Machines
LG WT-R801 keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 16, 2008 | LG WM0642H Front Load
GE WBSR3140DW Top Load Washer Logo
99 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
