Once wash begins the machine stops as soon as drum is about 20% full with water. Unable to drain water away to allow to move into next wash stage?
    Brigadier General:
  • 6,277 Answers
(If it is unable to drain the water away it could be the drain filter or pump which is blocked. Try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
GE Washer stuck in wash cycle and not draining.
humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
Mar 30, 2015 | GE Washing Machines
WHY WONT MY GENERAL ELECTRIC MODLE #WCXH208VOWW SPIN
Hi Darryl
Usually won't spin until water is drained to a low level.
Wont drain possibly because of blockage or pump blocked or stuck. (A Common Problem in Washing Machines)
So... As for further Troubleshooting
Process of elimination.
Where is Time Wheel set and what does it require to advanced to next stage.
Think of it as a Rotating Timer Switch stopping at each stage to check conditions.
The stages are controlled by sensors like "High Water Level"
The Sensor could be a simple Float Switch... eg. "High Water"
If water is High... Dont allow door to open and don't allow spin.
But do allow Pump to run.
It's all Plain Logic like used in computers (If, Then, Else)
Also Known AsTruth Tables
Good Luck
Truth Table Examples
Jan 04, 2013 | Washing Machines
Kitchenaid washer model kawe742wwh1; when it gets to wash cycle will stop completely.
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect. If the machine stops at the wash cycle after the pressure sensor works then it can be the control panel board as the processor or drive is faulty and so there is no output to the motor.
If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 04, 2012 | Whirlpool Washing Machines
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
My sink smells like septic
Assuming the smell is from food particals trapped in sink, and not from bad plumbing allowing gases back up the drain, I would do following.
Boil a large pot of water. Pour a cup full of ordinary bleach in sink, CAREFULLY pour hot water slowly into sink. AVOID breathing bleach fumes which will clear very quickly as it washed away.
For dish washer, use a cup full of bleach with about a quart of cool water in the bottom of dishwasher, close it and run it empty. Once it goes past the first stage, to where it begins to refill, you can interrupt it if you wish. Depending on model, may be better to let it complete.
Jan 30, 2011 | Dishwashers
Washer fills and drains at the same time.
Check for congealed soap in the Air Bell which is at the other end of the pipe for the pressure switch
Apr 02, 2010 | Kenmore HE2 Plus Front Load Washer
Fisher Paykel will not drain
I had the same problem. After cut the power off for at least 60 seconds and then back on, as the manual suggests, the problem remained. Therefore I started putting the clothes out and bailing the water out. Once the water was down about half way the pump started working. I suspect the sensor was "stuck". I cycled the washer without clothes and it worked fine. Still working after several loads of laundry. The water level sensor will probably need replacing sometime soon.
Dec 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
