Question about Kenmore 72872 Gas Dryer
Kenmore dryer m#110 70622990. Timer still runs after dryer is done. doesnt turn off. opened up back panel, and timer is hot. Bad timer, or bad mechanism going to timer?
  • 87 Answers
SOURCE: Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Posted on Jun 13, 2007
ginko
  • 19396 Answers
SOURCE: My Kenmore Model# 110 66652500
See the following hints from Repairclinic:
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
If it does not heat up, the element can also be faulty.
If you need to call a technician there is a phone number listed at the end of the user manual.
Posted on Sep 04, 2008
buffalonyman
  • 1865 Answers
SOURCE: kenmore 500 series gas dryer-timer
I can locate a replacement timer and assist you with replacement if you want to replace it yourself
Posted on Apr 15, 2009
localwonder
  • 6784 Answers
SOURCE: dryer timer not working on a kenmore dryer model 80 serious
HI, if this device isn't working, you will need to replace it. it cannot be repaired. it is designed to fail and when it fails, you will have to replace the entire timer control module.
This device control all aspects of the cycle you initiate.
Posted on May 23, 2009
garing
  • 998 Answers
SOURCE: No heat, dryer runs fine, timer not working
yes
Posted on Aug 07, 2009
Kenmore elite dryer # 110.70982990 timer problem
The timer is bad. Specifically the timer advance motor is going bad. It is a little electric motor located on the back of the timer. It movers the knob forward automatically as the dryer runs cutting down on time remaining. You usually have to buy the entire timer, you cant replace just that part.
May 17, 2016 | Kenmore Dryers
Dryer works but timer doesnt move
sounds like a bad timer or timer motor , check it with a multimeter, they have points inside and can seize up and burn metal to the contact points . then they stick at a certain point on the dial, u can actually open and repair it by cleaning the point contact up with sand paper a bit challenging job but can be done and save u more than 100.00 bucks
Sep 15, 2014 | Dryers
My kenmore 400 dryer timer doesnt move causing the electric switch go of every three minutes
Wow! Sounds like a couple different issues. First, make sure you have a free flow of air through your dryer duct work. The first place to check is where your dryer vent exits the home. With the dryer running, is there a good volume of air flowing through? No? Unplug dryer, ensure there are no kinks in the duct work, check for lint buildup in the duct work and on the back side (Inside of unit) of the lint trap. If you find no obstructions the blower motor may be bad or have a bad connection. The timer/selector switch could have a loose connection, gone bad or be dirty from lint buildup. If it's lint buildup around the switch you may be able to clean it with an old narrow 2" paint brush and some electrical contact cleaner. Make sure the appliance is unplugged when working inside the unit! Also, if you use electrical contact cleaner make sure you give it ample time to evaporate before testing dryer. If none of this helps, time to get on the phone. Good luck! :)
Feb 17, 2014 | Kenmore 400 6943 Dryer
Kenmore 110.63022101 When I set the timer and press the start button there is a clicking sound on the timer. I took the top part apart. When I press the start button and look at the back of the timer it...
are you saying the dryer won't start?did you check the thermal fuse located on blower wheel housing and high limit t-stats on the heater box?if the dryer isn't starting most of the time it's not the timer,if the dryer and vent line haven't been cleaned out most likely you popped a t-stat,or the belt could have broke,if the dryer runs to hot from being blocked with lint one of the t-stats will pop as a safety,unplug the dryer,remove the bottom panel,pull out the lint filter and remove the screws that hold the metal duct in place where the filter slides down into,look at the top of the blower wheel housing and you'll see two t-stats,the one on the left is the thermal fuse,remove at least one of the wires and read it out with a meter,if that's good check the two t-stats on the heater box usually it's the one in the back that could be bad,if you find either the thermal fuse or high limit blown you have to clean out the dryer and vent line,something is blocking the air flow and dryer is running to hot,if all these check good you could have a bad timer but you never said what the problem is you're having with the dryer.go here put your model number in and check out your dryer parts.
https://www.searspartsdirect.com/model-number/11063022101/0582/0151200.html
Dec 30, 2017 | Kenmore Elite Oasis ST 6806 Electric Dryer
The timer does not work correctly. The timer does not move and the dryer runs forever.
If the timer doesnt even advance in the time dry cycle then you have a bad timer. However you will need to make sure that your getting heat throughout the auto dry cycle because no heat will cause the dryer to run forever. Hope this helps _MJ_
Aug 17, 2010 | Kenmore Dryers
Kenmore 90 series Model # 66912691
most of the time if a dryer does nothing it is the door switch done bad or the mine fuse behind the back panel on the blower box,let me know more-mike
Mar 10, 2009 | Kenmore 62602 Electric Dryer
Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
Mar 02, 2009 | Kenmore Dryers
Dries clothes but runs too long & clothes VERY hot
Fixable and possibly a warranty claim. The timer is bad. You will need to get behind the control panel and remove the timer and replace the timer. First I would call whoever it is that yall bought the dryer through and see how long your warranty is. Most of the warranties are only 1 year. But if you bought a extended warranty then you are covered. The part can be found at repairclinic.com
Feb 17, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer Gas 110.73942101
Hi. thanks for the question. The problem you have is with a motor. it gets hot, and cuts off. pull dryer away from wall. clean venting. remove back panel, clean all dust. that will solve your problem thanks the appliance doc
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Timer doesnt move while dryer is on
Please page me here so that i can get back to you
May 19, 2008 | Estate TGDX640JQ Gas Dryer
Kenmore 72872 Gas Dryer Logo
46 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
