Question about Welch Allyn Atlas Monitor W/Ecg, Nellcor Sp02 & Nibp, Temperature, Respiration, Battery
Welch allyn atlas 6200 patient monitor: when plugged in with AC power cord, the screen says internal battery depleted...shutting off.....then shuts off.
4 Suggested Answers
SOURCE: Schiller Welch Allyn Cardiovit At 2
I HAVE SEEN THIS A FEW TIMES. I HAVE RELATED THIS TO THE PAPER CARRIES TRAY! CHECK THE TRAY AND MAKE SURE THE TIPS HAVE NOT BROKEN! THIS COMES FROM SOMEONE SLAPPING THE TRAY INTO PLACE INSTEAD OF COMPRESSING THE SMALL RELEASE.
MIKE
CALL
909-599-1789
Posted on Jan 29, 2009
  • 71 Answers
SOURCE: Hi My atlas monitor has begun to intermittently
intermittent problem most likely caused by a faulty patient cable with is the cable that goes from the monitor to the sensor. could be a problem in the cable itself or the connecters on the cable. best bet is to try swapping a known good cable but make sure it is the right part number. Some cables will fit but not work right. i can offer more help at info@mesasales.com I can supply new cables if nessesary.
Posted on Aug 31, 2009
  • 71 Answers
SOURCE: welch Allyn vital sign monitor turns off when we
There is not enough current in the battery to start the pump. Even when plugged in these will not work properly if the battery is going bad. These are not technically user replaceable but with a screwdriver and a new battery you can take care of it. I can help more if you like. info@mesasales.com
The Schiller AT-1 is not printing, when the patiente cable is conected the unit start to print and stop after 1 second and turn off. If I disconec the cable the unit keep printing
The Schiller AT1 is a battery powered unit. A common symptom of weak/defective battery's is that it will stop printing after 1-2 seconds of run. As to whether the patient cable effects this, I honestly don't know, It really shouldn't, baring some very weird internal short in the cable. The battery in the AT1 is beyond the average user to safely replace. Before anything else insure that the AC indicator light illuminates when the unit is plugged in. If not, you device might have a defective power supply. In either case, the unit needs repair in a Qualified shop.
Oct 28, 2011 | Schiller Welch Allyn Cardiovit At 2...
Welch allyn vital signs host communications reference manual
Link to Manual: http://www.welchallyn.com/documents/Patient%20Monitoring/Vital%20Signs%20Capture/Connex%20Vital%20Signs%20Monitor/DFU_VSM6000.pdf
Hope this helps.
Feb 28, 2011 | Welch Allyn Spot Vital Signs Nibp/Nellcor...
"Start" Button turns off vital signs monitor
Even if it is plugged in it will not operate correctly without a good battery. When the pump starts to take a blood pressure it draws a lot of power and this forces it to shut off. You should replace the battery and let it charge 12 hours and you should be in business.
If you have further questions you can contact me at wats@mesasales.com or through our website www.overstockme.com
Jun 12, 2010 | Welch Allyn Spot Vital Signs Monitor with...
Operating manuel for atlas monitor
www.welchallyn.com/.../Patient%20Monitoring/Continuous%20Monitoring/Atlas/6200-43e%20D.pdf
If you copy and paste this address into your browser it should take you to the manual. This address will allow you to download the manual to your computer. Or you can reach their customer service through www.welchallyn.com. I hope this helps! :)
May 05, 2010 | Welch Allyn Atlas Monitor W Ecg Nellcor...
Height for wall mounting
It does not matter where the monitors is mounted. Just make sure the patients arm is at heart level and you are fine.
Sep 15, 2009 | Welch Allyn Spot Vital Signs Monitor with...
Aug 07, 2009 | Welch Allyn Atlas Monitor W/Ecg, Nellcor...
Welch Allyn vital sign monitor turns off when we push the start button.
Feb 20, 2009 | Welch Allyn Atlas Monitor W/Ecg, Nellcor...
Machine will turn off on me
There is an internal battery in this machine. Machine reads that first. You need to replace that battery. It is almost $30.
Jan 15, 2009 | Schiller Welch Allyn Cardiovit At 2...
Welch Allyn Atlas Monitor W/Ecg, Nellcor Sp02 & Nibp, Temperature, Respiration, Battery Logo
107 people viewed this question
Top Welch Allyn Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Welch Allyn Medical Expert? Answer questions, earn points and help others
