I have a dlink 614 router connected to a DSL modem. I cannnot connect to the internet after I set up a PPOe configuration and username/password combination but it still wil not connect to the internet. When I use linksys router with the unsername/password configuration it works fine. I was on phone with both Dlink and verizon but they culd not solve my problem. I have done several resets and still have the same problem.
  • joecohn Aug 03, 2008
    Thank you Intrexx.
    I will try your suggestions about the firmware.
    I was actually beginning to think that itmay be a hradware problem. I didnt pursue it because I jst bought it brad new this week but you never know.
    by the way I meant to say this is a dlink 615 N wireless router.
  • 35 Answers
Hi There Joecohn,
Definitely, the username and password for your PPPoE connection is correct since that it works perfectly with your Linksys router. If you are getting a WAN IP Address from the status or summary page of your D-link router then you can lower down the MTU size of your router to 1492. If it didn’t work, upgrade or reflash the firmware, reset it back to the factory default and reconfigure the router for PPPoE connection again.
If it will not obtain an IP address or even if it has a WAN IP but can’t go online then we can consider it as a hardware failure on the D-Link router. Have it replaced.
Posted on Aug 03, 2008
  • Anna Marie Zamora Aug 03, 2008
    You are welcome joecohn . Goodluck! Hope you get it working by updating or reflashing the firmware. Good day!
My phone dsl line went down for 4 days. Once repaired, it seems like my router doesn't hook up with my modem. My computure say connected singnal strenght excellent but no connection to the internet. If I...
Possible reason why you lost the connection with your DSL line is that the router's configuration was changed. To reconfigure your Linksys router, you need to connect your computer wired to the router.
Open a Web Browser (IE, Firefox etc.) on the wired computer and type http://192.168.1.1 and press Enter. On the Username box leave it blank and on the password box type in admin. You will then see the router's configuration page. Under the Basic Setup tab you will see Internet Connection type on the left side of the screen. Click on the down arrow button and select PPoE, type in the Username and password that was provided by your DSL Internet service provider. Once your done click on the Save setting button on the bottom of the screen. Click on the Status tab on the top of the screen. Click on the Connect button and check if you will have an IP address on the Internet IP address option. If a valid IP address is present then you should have an internet connection then.
Feb 11, 2011 | Linksys Wireless-G WRT54G Router
Wireless is nonexistant
You need to bridge mode your modem. And when set it to bridge mode already. Connect the dlink router. Access the gui of the router. Enter there your username and password. Powercycle modem, router and computer. Check connections. I f this didnt work, set again your modem to default, connect your router. Configure your router with username and password. Powercycle again. Check if it is working.
Jul 16, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
I'm trying to set up my netgear WGT624v3 router with AT&T DSL. I used to have broadband and used the netgear router. Switched to AT&T DSL. Internet is much faster when I go from the modem to the...
Please follow steps to configure your router with AT&T
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
(still doesnot work then click on basicsetting, it will say does your internet connection require login,you need to click on NO then very bottom there would be router mac address you need to select USE COMPUTER MAC ADDRESS then click on apply
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolve issue
Thanks for using Fixya
Apr 17, 2010 | NetGear WGT624 Wireless Router
I need to change the modulation type on my modem to select g.dmt to make my internet connection more stable HELPPPPP!! i have NO clue how to do it. it's an ADSL 2+router DSL 504T.i am computer...
To configure the modem You will need to use the cd provided.
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_C3_QIG_v2.00.pdf
Or to configure without the cd follow the steps below:
  1. Connect the Adsl router with your computer.
  2. Use the network cable provided with the router.
  3. Connect the power cable to the modem, it will light on firmly with a green button on.
  4. Open your web browser and type the ip address: http://10.1.1.1
  5. Default username and password is:
  6. User-name: admin
  7. Password: admin
  8. Use the quick setup wizard.
  9. It will be more easy for you to configure it.
  10. Be sure to have the username and password from the ISP for the internet access, you may need to reconfigure it from start. or if you may need to reset the modem
  11. At times to access your modem you will need to set the ip of your network card to the same range.
  12. To set the ip go in control panel then open network connection
  13. Doulbe click the local area connection.
  14. open Internet Protocol Open Tcp/ip
  15. then set your ip Like: 10.1.1.5
  16. ok
  17. ftp://files.dlink.com.au/Products/DSL-504T-GenII_NZ/Manuals/
I am enclosing a manual for you.
If you Need further help do not hesitate to revert back
Ok cheers
Uttam
Feb 13, 2010 | Computers & Internet
How can i configure broadband into two pc?
The best thing to do is to purchase a router so that you could share the internet connection on both systems.
Jun 06, 2009 | Microsoft Computers & Internet
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Dec 21, 2008 | Computers & Internet
Using a ppoe connection to a DI-524 is it necessary to put a modem in line?
DSL connection:
Computer -> Router(Dlink) -> DSL Modem -> Telephone wall jack/outlet
OR
Computer -> DSL Modem -> Telephone wall jack/outlet
PPPOE = using a username/password combination to authenticate the connection to the ISP.
Nov 04, 2008 | Computers & Internet
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
Speedstream modem 4200
put the modem in bridge mode and then connect a DSL/cable router to it...you'll have to configure the PPOE if its DSL... Cable is a little easier because there usually is a MAC authientication not username and password...plug dsl/cable router into cable modem...turn both off for about aminute then turn modem on first then router... Be careful most routers with wireless have it enable with no security by default...turn it off or set securty (wirelss that is)
Aug 27, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
