Question about Philips 19PR19 19" TV
TV is hooked up to cable,but only blue screen and a/v appear.
Had a friend try to hook up playstation 2 they couldnt. I then went back to plug cable into a/v once did that only a blue screen came up with a/v input in. I tried with the remote control to reset the tv as well as do the autoprogram it will not let me. The tv just stays blue .I do not get any cable reception and the tv in the menu is already set to cable -yes, Please help as the tv was working fine before the attemp to hook up the playstyation which was unsuccesful as well as the tv now being unable to function propelry.I am now with a tv that has only a blue screen ans says a/v inout in.
  • Anonymous Aug 08, 2008
    how to install cable to my tv because it doesnt have the holes where you put some cables
  • Anonymous Sep 28, 2008
    Same problem, i moved my TV for awhile and when i plugged it back into the cable the screen is only blue now and i get no channels
  • 833 Answers
Okay...you have a place on your remote which says input or tv/vcr or something like that. You may also have an input menu. You've got to find that. Right now, you're set on one or more of the component (a/v) inputs your set has. You've got to move that back to the tv input. If you are using a cable input or antenna input...these use one connector with a screw on fitting on it.
If you have a tv that does not have cable input...antenna cable, you'll need a balun adapter. Available at any electronics store. If you're trying to input rca style plugs...not every tv has this...especially if more than 10 years old.
Posted on Aug 11, 2008
WELL???? PDP4210EA hooking up to it?
I was able to find a service manual online which lists the inputs for that TV as the following:
  • RF connector (cable/antenna)
  • Composite (yellow video, red/white audio)
  • S-Video
  • Component (red/green/blue video, red/white audio)
  • D-Sub (analog PC connector)
  • DVI (digital PC connector)
Your Playstation would need to be plugged into either the component or composite connectors depending on which Playstation you have. The Playstation 1, Playstation 2, and Playstation 3 all can use the same composite cable, and the Playstation 2 and Playstation 3 can both use the same component cable. The Playstation 4 only uses HDMI, which your TV doesn't support, so you would need to use an HDMI to component converter (under $20 on Amazon).
As for the Roku, same rules apply, but it again depends on your Roku model.
Oct 24, 2017 | iLO Televison & Video
I have the system hooked up and it comes on but not o the tv screen do i need the hd cable to make it work it is a flat screen tv please let me know what to do i have playstation 2 already hooked up and...
Are you using the AV connector cable? If so look on your tv for an av channel. Best thing to do though is Try using a HDMI cable. Most tv's recognise when a HDMI cable is plugged in and the tv switches automatically to the HD channel.
Hope this helps.
LJ.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
I just get a blank screen with no sound or anything when i turn it on
I once had this issue, the solution was hard to find(five hours), but fairly simple. (This works for HDMI cable set up, but I'm not sure concerning AV)
Note: Yes, the solution sounds ridiculous, but for this issue, it works.
1. Unhook your PS3 from the current TV/Computer screen you have it hooked up to.
2. Hook it up to a different TV/Computer screen that you have or a friend may have.
3. Power on the PS3 and it should have a screen and everything and work just fine.
4. Hook it back to your original TV/Computer screen and power on the PS3 and it should work fine there again aswell.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
May 04, 2010 | Sony PlayStation 2 (PS2) Console
No visual picture
If it's a setting on the PS3 then just hook it up to another T.V. set it back to default and hook it back up to your other T.V.
May 28, 2009 | Sony Playstation 3 (PS3) Console
Cant find channel for playstation 2
I have got a Finlux plasma television and i cant find my instructions. I have just been given a play station 2 and i have put it all correct in my television but its not coming up on my screen. I dont know what channel to put it on, please can you help me!?
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
My ps3 only works with hdmi cables?
Did you try holding down the Power button until you heard 3 beeps? It is not uncommon for the video output to exceed the resolution of different television. This hard reset feature was added to troubleshoot such a problem, factory resetting the video settings.
Apr 02, 2017 | Sony Playstation 3 (PS3) Console
No picture for playstation 2
Could possibly be that it is not connected up correctly, or your playstation has died. If you have access to another playstation, hook it up to your cables as they are hooked up. If the screen works. Your playstation has died.
If not, and you have the same issues, try their cables, and if that doesn't work. You have it plugged in incorrectly.
May 01, 2008 | Sony PlayStation 2 (PS2) Console
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
Feb 18, 2008 | Olevia LT27HVX 27 in. LCD Television
Philips 19PR19 19" TV Logo
279 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
